To install 488 gears or not? Thanks for the help!
+ Reply to Thread
Results 1 to 15 of 15
Like Tree5Likes
  • 1 Post By StevJ
  • 1 Post By Art64
  • 1 Post By chphilo
  • 1 Post By escondidotundra
Thread: To install 488 gears or not? Thanks for the help!
  1. #1
    Rookie Toys Rock is on a distinguished road.
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Default To install 488 gears or not? Thanks for the help!
    Hi, I'm considering installing 488 gears on my 2011 Tundra 4x4. I've had some modifications: 6" lift (Pro Comp), 35" tires... These modifications have caused a loss of about 5mpg, which I was pre-warned about. I've seen conflicting info, on whether or not changing the gears will help my fuel consumption or not. I'm also wondering if there are any other issues with this change? One post I saw earlier said something about many lights on the dash coming on after the gear change. I would appreciate any help. Thanks!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Posts
    892
    Liked
    84 times
    Rep Power
    6935
    Default Re: To install 488 gears or not? Thanks for the help!
    If you're thinking of doing this only to regain some of the fuel mileage lost due to the oversized tires, there's a question of practicality: Will you have the Tundra long enough that the fuel mileage regained will offset the cost of acquiring and having these gears installed front and rear?
    The lift had a negligable affect on fuel mileage.
    Steve
    Toys Rock likes this.
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  4. #3
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    I do plan to keep the truck for a long time. I purchased my last truck, new, in 1996, a Dodge Cummins, and sold it with over 220000 miles. So, if I really will see a gain of 1-2 MPG, it would be worth it to me. Thanks!
  5. #4
    Supporter Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64's Avatar
    Join Date
    Jul 2006
    Location
    Perris, CA
    Posts
    1,400
    Liked
    2 times
    Rep Power
    282
    In your case, it's well worth it. It will help restore the torque on low rpm's for towing, hauling heavy or if you just want to accelerate quick.
  6. #5
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Veteran Member chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo has earned a bachelors in rep power. chphilo's Avatar
    Join Date
    May 2010
    Location
    PA
    Posts
    1,096
    Liked
    70 times
    Images
    17
    Rep Power
    17147
    You mean 4.88 gear, correct? That will certainly help getting some of the power lost (due to larger tires) back, but not mpg. Unfortunately, it is difficult to get both power and mpg improvement. See the chart attached below.
    Attached Thumbnails Attached Thumbnails To install 488 gears or not? Thanks for the help!-gear_ratios.jpg
    2010 Toyota Tundra, Crewmax, 4x4, 5.7, TRD Off Road, SR5, Silver Sky Metalic
    Brushed Stainless Steel Stepboards, Tinted Windows, Pioneer AVIC Z140BH, Pioneer ND-BC5 Rearview Camera, Metra Axxess Steerinng Wheel Control Interface, Line X Extra with Color Match, ValuGard Undercoat, ValuGard Rust Inhibitor, AVS Window Visor, Clazzio (black/red), TRD Cat-Back Exhaust System, TRD Intake, Toyota Hood Protector, Husky WeatherBeater Floor Liners, AMI TRD Third Light Brake Cover, Westin Ultimate Bull Bar, Westin Chrome Off-Road Lights, TRD License Plate Frame, B&W Tow & Stow, Moto Metal 961, Bushwacker fender flares, G-Tek Door Sill Protector, BAKFlip F1
  8. #7
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Veteran Member escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra is more than famous, they're infamous. escondidotundra's Avatar
    Join Date
    Jan 2008
    Location
    san diego, ca
    Posts
    866
    Liked
    149 times
    Rep Power
    3018
    With the bigger tires its as if you're driving uphill everywhere you go. With the new gears 4.88 it brings you back to level ground. It's too bad you can't use 5.14
    BAmufflers performance sound for your Tundra without the drone!!!
  10. #9
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Thanks, If you don't mind me asking, how long have you been running 4.88's?
  11. #10
    Join Date
    Jan 2008
    Location
    san diego, ca
    Posts
    866
    Liked
    149 times
    Rep Power
    3018
    Quote Originally Posted by Toys Rock View Post
    I've had em since about 2007. I run 31.5" tires. I used to put 315-75/16's on my truck and it really bogged it down compared to the 31.5's or 305-65/17. That's why I say, "too bad you can't run 5.14's. idk if the 2gens have that option yet. I know that it's available for my 1gen but with the ring gear only 8.4" compared to your 10.5" I'd really strip teeth.
  12. #11
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Ya, you don't want to break your truck. It looks cool by the way! Thanks for the help!
  13. #12
    Join Date
    Jan 2008
    Location
    san diego, ca
    Posts
    866
    Liked
    149 times
    Rep Power
    3018
    Haha. I've broken 3 Detroit lockers. (Complete pos btw) and 4 sets of Randy's ring and pinion/ Yukon. Stick with the name brands no matter what ratio u go. With 35's at least go 4.88 and your truck wi drive normally again. I believe justdiffs is trying to put together a group buy right now
  14. #13
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Wow, you must be doing some serious 4xin!
  15. #14
    Join Date
    Jan 2008
    Location
    san diego, ca
    Posts
    866
    Liked
    149 times
    Rep Power
    3018
    My truck is 2wd... 300hp. 4450lbs. Knee high whoops 65mph. 8.4" ring gear. Lol it's the ring gear that is the weak link
  16. #15
    Join Date
    Nov 2012
    Location
    yakima
    Posts
    9
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Have a great Thanksgiving!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
