Need Advice on Double Cab under seat storage solutions
+ Reply to Thread
Results 1 to 10 of 10
Thread: Need Advice on Double Cab under seat storage solutions
  1. #1
    Junior Member xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some. xsnrg has done just about everything...and then some.
    Join Date
    Aug 2007
    Location
    Durham, NC
    Posts
    222
    Liked
    10 times
    Rep Power
    816
    Default Need Advice on Double Cab under seat storage solutions
    Dad is asking for an under-seat storage box/organizer for his 2012 Limited Double Cab. I have the CrewMax, so I've never looked into them. I see there are several options out there, including Husky, Du Ha, and I believe Toyota has one also. Can anyone who has one comment or give advice as to which one you went with and why? Thanks!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj is more than famous, they're infamous. dickinsonj's Avatar
    Join Date
    Jun 2003
    Location
    Ashville, OH
    Posts
    964
    Liked
    11 times
    Images
    4
    Rep Power
    2880
    Default Re: Need Advice on Double Cab under seat storage solutions
    I got a Du Ha for my Limited DC Tundra. Toyota strangely does not make one compatible with the JBL sub woofer in my truck. I don't remember why I picked the Du Ha over the Husky but I have no complaints with mine so far and it was incredibly easy to install.
    2011 Tundra DC Limited 5.7L 4x4 TRD Off Road with towing package, JBL Navigation and Factory installed TRD dual exhaust. Mods: Toyota stainless steel stepboards, Toyota bed mat, WeatherTech floor liners, AutoBahn shift knob, Truxedo LoPro tonneau, TRD Racing logo receiver cover, TRD rear sway bar, Du-Ha underseat storage, G-Tek Fab black carbide texture door sill protectors.
  4. #3
    Junior Member 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra is a pinnacle in their own mind. 11Tundra's Avatar
    Join Date
    Jan 2012
    Location
    United States
    Posts
    366
    Liked
    80 times
    Rep Power
    2310
    Quote Originally Posted by xsnrg View Post
    The Du-Ha storage unit has much more storage area than the OEM Toyota version, especially for longer items like shotguns, rifles, collapsible fishing rods, and thicker, taller items. In fact, the Du-Ha comes with plastic, foam inserts specifically designed for storing shotguns and rifles. FWIW, I can store my entire weight distribution hitch (bars, hitch assembly, chains, brackets, etc.) inside my Du-Ha (with room to spare) with the rear seats completely down.
    The bottom of the rear seats cover the open Du-Ha unit which maximizes storage capability. The OEM Toyota version is flatter (with less vertical space); however, it has dedicated covered compartments that enable smaller items to be stored inside so they're not exposed when the rear seats are in the raised position.
    For some the OEM Toyota version might be preferable when placing large, flat items (like cardboard boxes) in the back with the rear seats folded up. With the compartment covers all closed, the OEM Toyota version would offer a large, flat area for storage (with the rear seats folded up). The Du-Ha is more of an open cavity with the rear seats folded up and would not offer as much support.
    They're both excellent, well made units. Just a matter of personal preference.
  5. #4
    Join Date
    Aug 2007
    Location
    Durham, NC
    Posts
    222
    Liked
    10 times
    Rep Power
    816
    Thread Starter
    anyone go with the Husky? Curious how it differs from the Du Ha better or worse. Were there others out there to consider as well? Based on feedback so far, I'd be leaning toward the Du Ha that is sub-woofer compatible since he has a Limited.
  6. #5
    Junior Member v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold.
    Join Date
    Dec 2010
    Location
    TX
    Posts
    197
    Liked
    23 times
    Rep Power
    11
    I went with the Du-Ha. Being able to partition it off is a huge bonus as it keeps things from sliding around and getting as lost. I have stored rifles, large umbrellas and a fishing rod under the seat without issues. i would say the husky is a slight step up from the Toyota box, but I would not consider it myself.
  7. #6
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,564
    Liked
    194 times
    Images
    8
    Rep Power
    32267
    Here's what I did:
    DIY: - Underseat storage
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  8. #7
    Lurking Member MarkCNP is on a distinguished road. MarkCNP's Avatar
    Join Date
    Feb 2008
    Location
    Alberta
    Posts
    26
    Liked
    1 times
    Rep Power
    6
    Old ammunition box.
    Need Advice on Double Cab under seat storage solutions-img_1966.jpg Need Advice on Double Cab under seat storage solutions-img_1973.jpg
    Current:.....2007 Tundra Double Cab Limited 4x4
    Former:......2005 Tacoma TRD Access Cab 4x4
    ................1992 4Runner SR5 4x4
    ................1982 Pickup SR5 4x4
  9. #8
    Join Date
    Aug 2007
    Location
    Durham, NC
    Posts
    222
    Liked
    10 times
    Rep Power
    816
    Thread Starter
    Thanks, guys!
    Mendosy, I love your solution. I'll probably end up going with the Du Ha since it's a Christmas present and I'm in another state.
  10. #9
    Supporter Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla's Avatar
    Join Date
    Apr 2000
    Location
    IL
    Posts
    1,043
    Liked
    85 times
    Images
    47
    Rep Power
    111852
    the problem with these is if you put the seats up you lose a lot of floor space. That's where my dog hangs out so I have never got one of these. It would be nice though
    2010 Tundra 4x4 5.7 Limited, Slate, TRD RW Wheels with 33" Cooper ST Maxx
    http://www.tundrasolutions.com/forums/image.php?type=sigpic&userid=348&dateline=12472564  47
  11. #10
    Junior Member Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu has done just about everything...and then some. Chelu's Avatar
    Join Date
    Jan 2011
    Location
    Pacific North West
    Posts
    136
    Liked
    5 times
    Images
    2
    Rep Power
    1068
    Quote Originally Posted by 11Tundra View Post
    I went with the OEM after it was offered with 20% off at the dealership. And I went ahead and did the rear seat folding mod too.
    "If it has wheels or skirt, it will give you problems!"
    2011 4x4 TRD 5.7, Barcelona Red, Dbl Cab, TOW Pkg, DiamondBack LT Truck Cover, Husky WeatherBeaters, Fog Light and rear seats fold-down MODS.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
