Question 2009 Tundra Rock Warrior ride
+ Reply to Thread
Results 1 to 9 of 9
Thread: 2009 Tundra Rock Warrior ride
  1. #1
    Rookie firefightermike is on a distinguished road.
    Join Date
    Jul 2012
    Location
    Prescott Valley, AZ
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default 2009 Tundra Rock Warrior ride
    Hello,
    First post ever. I have had my 2009 Tundra Rock Warrior for about 5 months now. It has 20" BMF Novakane wheels with 305/55/20 Nitto Terra Grapplers, and it seems like a rough ride. I am contemplating buying the stock Rock Warrior TRD 17" wheels to try to get a smoother ride. Will my ride be smoother if i kept the 20" and put a 275/55/20 Cooper Discoverer AT3 or will i have to go with the smaller wheel to get the better ride. Also, i might be selling the wheels if anyone is interested.
    Thanks for your help!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence. G BUDDENHAGEN has blessed us with their presence.
    Join Date
    Feb 2012
    Location
    GALVESTON, TEXAS
    Posts
    112
    Liked
    4 times
    Rep Power
    28
    Default Re: 2009 Tundra Rock Warrior ride
    With the Nitto tires it should be smooth. You are probally running to much air pressure do you have the truck level with spacer kit ?
  4. #3
    Junior Member Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence. Tundergas has blessed us with their presence.
    Join Date
    Aug 2011
    Location
    Las Vegas
    Posts
    136
    Liked
    17 times
    Rep Power
    36
    Your ride should not be much different between the two honestly. As G-Budd said, check the air pressure. You've got the cat's meow wheels and tires. If you have the cash, keep them and get some stockers. You are in wheeling paradise down in PV. I'd be crazy to take those BMF's out there and destroy them.
  5. #4
    Junior Member jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light. jcole is a glorious beacon of light.
    Join Date
    Nov 2011
    Location
    NC
    Posts
    90
    Liked
    10 times
    Rep Power
    163
    [QUOTE=firefightermike;1843941]Hello,
    I would agree with checking the pressure to see if its too high. I would also check to see what ply the tires are. If they are 8 or 10 ply you are going to have a rougher ride. If you go to the 275 55 20 you will be losing over 1/2" of sidewall which will probably be a little stiffer than what you have. If your wheels are wide and need the 305 you will be stretching the sidewall of the 275 making it even stiffer. If you want to change tires a 275/60 will be much closer to the size that you currently have. I recently bought 275 60 20 cooper at3 from discount tire direct on ebay. At the time discount tire was offering a $100 rebate and cooper had a $75 rebate. If you want to replace your tires I would hold out for a little while to see if either/both of the rebates will come back.
  6. #5
    Supporter Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla's Avatar
    Join Date
    Apr 2000
    Location
    IL
    Posts
    1,043
    Liked
    85 times
    Images
    47
    Rep Power
    111852
    Quote Originally Posted by firefightermike View Post
    Hello,
    What air pressure are you running?
    And yes, 20" wheels vs 17" wheels will make a difference due to less tire sidewall between the two.
    I have 17" rock warrior wheels and new cooper st maxx tires which are load E. I run 45psi now and the ride is fine, it's actually better than when I had my P285/70/17 firestones due to the extra weight of the tire.
    they run butter smooth and only have a little tire noise for how aggressive they are. (more aggressive than the Nittos)
    2010 Tundra 4x4 5.7 Limited, Slate, TRD RW Wheels with 33" Cooper ST Maxx
    http://www.tundrasolutions.com/forums/image.php?type=sigpic&userid=348&dateline=12472564  47
  7. #6
    Join Date
    Jul 2012
    Location
    Prescott Valley, AZ
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thank you all for the answers. I am currently running the tires at 43 psi. I will drop it a little more and see what it does for the ride. I do have a leveling kit put on that allows 33" tires.
  8. #7
    Join Date
    Apr 2000
    Location
    IL
    Posts
    1,043
    Liked
    85 times
    Images
    47
    Rep Power
    111852
    you don't need the level kit for 33". the rock warrior comes stock with 33" LT285/70/17. My st maxx are a full 33" with 18.5 32nds of tread, and I am full stock with rock warrior wheels, limited TRD truck
    I think it may be the 20" dubs...They are well known to degrade the ride quality vs 16" or 17" wheels with tons of sidewall.
    go drive a stock rock warrior at the dealer for a free comparison and then you'll know for sure.
  9. #8
    Join Date
    Jul 2012
    Location
    Prescott Valley, AZ
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Will Do thanks! Anybody else have the Nitto Terra Grapplers? And what pressure you running them?
  10. #9
    Join Date
    Feb 2012
    Location
    GALVESTON, TEXAS
    Posts
    112
    Liked
    4 times
    Rep Power
    28
    i beleive most people run 35psi on a 33inch tires on these trucks. it works for me and many others. ran 35 psi on my z-71 with 315-70-17 duratracs or bfgs and no problems.also a spacer level kit will and sometimes affect ride quality. like the other memebrs here have said drop the air down. try 35psi and run it for a while. also find out what level kit you have on your truck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
