Question 2007 tundra electrical problem
+ Reply to Thread
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Tundra Tin Man
  • 1 Post By NJGUY122
Thread: 2007 tundra electrical problem
  1. #1
    Join Date
    Jun 2008
    Location
    Rahway,NJ
    Posts
    23
    Liked
    1 times
    Rep Power
    290
    Default 2007 tundra electrical problem
    My problem is the dash and head lights flicker while driving and sometimes they will go out momentarily along with the radio and gauges, the engine speed and performance are not affected. The battery is fully charged and the alternator is new and load test good. Any help would be appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member Phreak's Avatar
    Join Date
    May 2012
    Location
    Pasco, WA
    Posts
    31
    Liked
    3 times
    Images
    1
    Rep Power
    181
    Default Re: 2007 tundra electrical problem
    Sounds like a bad ground to me. I don't think the headlights and the dash lights are on the same circuit so it would have to be a major ground if it was. Unfortunately I'm no expert, I turn to these guys for all my wiring advice. Someone here will have a good idea I'm sure.
    2008 Crewmax SR5 TRD, Flowmasters, Leveling kit, Blacked out grill, Plastidip OEM Wheels
  4. #3
    Join Date
    Jun 2008
    Location
    Rahway,NJ
    Posts
    23
    Liked
    1 times
    Rep Power
    290
    Thread Starter
    I was thinking a ground issue but all the grounds are clean and tight, the flickering and loss of the lights can be affected by acceleration also.
  5. #4
    Join Date
    Jun 2008
    Location
    Rahway,NJ
    Posts
    23
    Liked
    1 times
    Rep Power
    290
    Thread Starter
    Still haveing this problem, dash and head lights flicker while driving and sometimes they will go out momentarily along with the radio and gauges, the engine speed and performance are not affected. The battery is fully charged and the alternator is new and load test good. Any help would be appreciated. the problem is made worse with acceleration. I have a after market remote start with the security bypass for the chip in the key, could the bypass be going bad causing problems? Any help would be appreciated.
  6. #5
    Join Date
    Nov 2008
    Location
    Plant City (Tampa) FL
    Posts
    228
    Liked
    8 times
    Rep Power
    775
    Ask MENDONSY, who is the keeper of all things electrical............
    mendonsy likes this.
    Never pick a fight with an old man,
    if he's too old to fight, he'll just KILL YOU
    Tundra Tin Man
  7. #6
    Junior Member 11Tundra's Avatar
    Join Date
    Jan 2012
    Location
    United States
    Posts
    465
    Liked
    114 times
    Rep Power
    2818
    Quote Originally Posted by NJGUY122 View Post
    Sorry to hear you're still having problems. FWIW, there are hundreds of grounds on this truck. I'd take a guess and say you've probably got an intermittent ground somewhere in your dash that's in common with your dash lights, headlight switch, radio, etc. The fact it's worse when you accelerate may lead one to believe it's also vibration related. I've attached the schematic for the Gen2 Tundra which might prove useful.
    Unfortunately, the fact that you've had an aftermarket remote start installed kinda complicates things because it may add another variable into your problem equation. There's no telling what he may bumped, disconnected, and/or modified. Unless the person who installed your remote starter gave you a schematic of what he installed it may make troubleshooting more difficult.
    Good luck!
    Attached Files Attached Files
  8. #7
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,127
    Liked
    349 times
    Images
    8
    Rep Power
    42968
    Thanks TTM!! I was just looking in my PDF library on TS for the wiring diagram.
    I am inclined to agree that it's a connection problem. Maybe this wiring diagram will help you find it.
    headlights.pdf
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  9. #8
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    21
    Posts
    2,716
    Liked
    1094 times
    Images
    38
    Rep Power
    44773
    i had a similar problem after i installed a new alternator but i never experienced them totally going out. even though im not a 2nd gen owner i would take a look at the harness plug that is on the back of the alternator. this plug it what tells you if the alternator malfunctions like if the belt flies off and brings up the battery light on the dash. without it making a good connection it can cause the alternator to cycle on and off rapidly or even go off for a few secs and then flash back up.
    but most likely its a ground issue but this is worth a shot to check off the list of things to check.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 217,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s, 3" LED flood cubes, 4" LED hyperspot Pods
    CBTMA Member
    For Sale: LED Light bar
  10. #9
    Join Date
    Jan 2009
    Location
    SC
    Posts
    363
    Liked
    80 times
    Rep Power
    3142
    The second I read after market remote starter I question the installation and its connections. I would start there and see how it is tied in and confirm the connections are sound and secured especially since you mention acceleration affects it and probably rough roads. That is where I would start.
    Your headlights probably flicker with the dash because the dash powers the headlight switch and relays for them.
    Hewitt Tech Inc Webstore Home of the Original SAIS Bypass Kit
  11. #10
    Join Date
    Jun 2008
    Location
    Rahway,NJ
    Posts
    23
    Liked
    1 times
    Rep Power
    290
    Thread Starter
    Thanks for all the help, I have a lot to work with now and the diagrams will be a big help I'll update you if I figure it out.
    DanielAcosta likes this.
  12. #11
    Join Date
    Mar 2013
    Location
    Jacksonville, FL
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Did you ever find an answer to your problem? I have had similar symptoms on mine and believe it may be the alternator getting ready to die.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
