Heat a/c troubles, diagnostic codes
+ Reply to Thread
Results 1 to 3 of 3
Thread: Heat a/c troubles, diagnostic codes
  1. #1
    Rookie kkennett is on a distinguished road.
    Join Date
    Dec 2010
    Location
    Suwanee, GA
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Heat a/c troubles, diagnostic codes
    2007 Tundra Limited
    My HVAC is having troubles, with a number of symptoms. The driver and passenger sides are blowing hot/cold air with the temperature settings equivalent. The heat keeps putting out way beyond the set temperature. Also, the hvac has begun to forget its digital settings and reset itself on startup. I have looked up and found others with that problem on this forum.
    I have accessed the HVAC diagnostic codes by pressing and holding auto/recirculate at start up. It then delivers three codes, 21, 24, and 46. I have not been able to find online a resource for what these codes mean. I take it 21 is for the solar sensor, but I did the check at night, so that could be it. 24 and 46 I have no idea. Anybody with a thought? I could really use the help.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,561
    Liked
    194 times
    Images
    8
    Rep Power
    32267
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Join Date
    Dec 2010
    Location
    Suwanee, GA
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: Heat a/c troubles, diagnostic codes
    Thanks a million. I really appreciate it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
