Question Instrument Panel Issue
+ Reply to Thread
Results 1 to 8 of 8
Thread: Instrument Panel Issue
  1. #1
    Rookie dlangesr is on a distinguished road.
    Join Date
    Aug 2010
    Location
    Colorado
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Instrument Panel Issue
    I have an intermittent problem w/ my instrument panel that is becoming more frequent. The oil pressure and tempurature guages die; the VSC off warning comes on and flashes and the Auto LSD symbol (car skidding) comes on in the far left cluster; and the ABS warning light comes on. and the Outside Temp next to the clock goes blank. Until now this has just been a nuisance. But, I just found out that when this occurs the 4WD actuator switch doesn't work and I have no ABS (so a safety issue in the snow). There must be some common component for all of these functions. More than just a fuse; ? is it a relay? Is it something that can be fixed easily DIY or do I have to go to a mechanic or dealer for service?
    thanks!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Sparkland is on a distinguished road.
    Join Date
    May 2012
    Location
    Thornton, CO. USA
    Posts
    77
    Liked
    4 times
    Rep Power
    2
    Default Re: Instrument Panel Issue
    I would say your battery is failing--that causes chaos in the dash cluster.
  4. #3
    Join Date
    Aug 2010
    Location
    Colorado
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Has original battery - but, still puts out 12.34V and alternator 14.2V. Has good cold cranking power. WIll consider the battery if no other solutions brought forth.
    by the way - this is a 2008 dbl cab w/ 8ft bed
  5. #4
    Junior Member Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some. Tundra Tin Man has done just about everything...and then some.
    Join Date
    Nov 2008
    Location
    Plant City (Tampa) FL
    Posts
    221
    Liked
    6 times
    Rep Power
    773
    [Clean the posts and the ends good, tighten down very snug.....good luck
    Never pick a fight with an old man,
    if he's too old to fight, he'll just KILL YOU
    Tundra Tin Man
  6. #5
    Junior Member v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold. v4lu3s is a splendid one to behold.
    Join Date
    Dec 2010
    Location
    TX
    Posts
    195
    Liked
    23 times
    Rep Power
    11
    might see if a parts store can load test your battery
  7. #6
    Junior Member asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light.
    Join Date
    Dec 2005
    Location
    Mechanicsburg, PA
    Posts
    59
    Liked
    10 times
    Rep Power
    186
    Test the battery, and remove, clean and re-connect the battery cables, as mentioned above. Then take a look at the grounds. Don't know where they all are, but give it a good look and see if any are loose or corroded.
    I have seen a 'good' battery cause all sorts of crazy issues, it had a bad cell that would short out on occasion, but tested fine. At 5 years old, the battery may be at the end of it's life.
  8. #7
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,559
    Liked
    194 times
    Images
    8
    Rep Power
    32267
    Testing the grounds and battery can't hurt a thing, but based on the wiring diagram I suspect that the problem is actually a bad combination meter (gauge cluster).
    The VSC and ALSD lights both being on can indicate a CAN bus communications issue and the power for all the gauges comes through the MET-B fuse so a power issue should kill all of the gauges at once. The only way to know for sure is to have a Techstream connected to it while the problem is happening.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  9. #8
    Junior Member ScottTRD is on a distinguished road. ScottTRD's Avatar
    Join Date
    Mar 2004
    Location
    SJ AFB
    Posts
    107
    Liked
    1 times
    Rep Power
    10
    Did you ever get this problem fixed? Mine is doing sorta the same thing except they are out all the time. Fuse is good. At dealership now and so far they can't find the problem.
    2007 Tundra 4x4 Crew Cab
Posting Permissions
  • You may not post replies
  • You may not edit your posts
