Bilstein 5100 and TRD springs
+ Reply to Thread
Results 1 to 8 of 8
Thread: Bilstein 5100 and TRD springs
  1. #1
    Join Date
    Dec 2010
    Location
    San francisco
    Posts
    16
    Liked
    7 times
    Rep Power
    0
    Default Bilstein 5100 and TRD springs
    I have a 2011 CM Non TRD. I was looking to to level out the front suspension.
    I was looking to put Bilsein 5100's all around. What i was looking to do was pick up some TRD springs and put them on the bilstein's.
    Now will the TRD spring fit into the non TRD upper mount? Or would i need to purchase TRD upper mounts.
    Also is there is a different in TRD and TRD off road springs?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member phobos512's Avatar
    Join Date
    Feb 2008
    Location
    Ridgecrest, CA
    Age
    35
    Posts
    49
    Liked
    6 times
    Images
    6
    Rep Power
    8
    I have had this exact question also. In the research I've done looking at parts diagrams it looks like the springs vary by cab, wheelbase, drive type and offroad/non-offroad (offroad includes TRD offroad and Rock warrior). It looks like the front coil springs and the rear leaf springs all vary. OE prices to get the TRD offroad springs run about $1400 new, which is nuts (the rear leafs run $560 each side new).
    Personally I'm looking at Rancho Quicklift Loadeds swapping to TRD offroad springs, the 9000xls in the rear and then 2" Coachbuilder shackles (leaving the stock leafs or maybe swapping to OMEs and forgoing the shackles).
    Sent from my iPhone using AutoGuide.com Free App
    Matt
    2012 Toyota Tundra Crewmax Platinum 4x4
  4. #3
    Join Date
    Dec 2010
    Location
    San francisco
    Posts
    16
    Liked
    7 times
    Rep Power
    0
    Thread Starter
    Default Re: Bilstein 5100 and TRD springs
    Quote Originally Posted by phobos512 View Post
    Was that quote for shocks and springs?
    I was just looking to use TRD coils on the bilstein 5100.
  5. #4
    Supercharged Member SE2000's Avatar
    Join Date
    Jan 2007
    Location
    Albany
    Posts
    4,604
    Liked
    188 times
    Rep Power
    247449
    I don't think the springs get changed for TRD other than the lowered kit. TRD changes the shock/strut part
  6. #5
    Join Date
    Feb 2008
    Location
    Ridgecrest, CA
    Age
    35
    Posts
    49
    Liked
    6 times
    Images
    6
    Rep Power
    8
    Quote Originally Posted by SE2000 View Post
    Well they list different parts for offroad or not offroad packages and another member who had installed the Ranchos on his truck found a significant difference between the springs that came on his Rock Warrior and those on a non offroad. So I'm pretty sure they're different.
    The price I listed in my last post was coil springs and leaf springs only. Stock parts from Sparks for offroad are $132/coil and $560/leaf pack before shipping.
    Sent from my DROID RAZR HD using AutoGuide.Com Free App
    Matt
  7. #6
    Join Date
    Dec 2010
    Location
    San francisco
    Posts
    16
    Liked
    7 times
    Rep Power
    0
    Thread Starter
    Do the non trd upper coil mount for the trd coil spring ?
  8. #7
    Supporting Vendor YotaDan's Avatar
    Join Date
    Oct 2010
    Location
    Grants Pass
    Posts
    321
    Liked
    48 times
    Rep Power
    680
    Why are you wanting to run the TRD springs? The Bilstein 5100s are adjustable and will allow you to level out the truck with the stock springs.
  9. #8
    Join Date
    Dec 2010
    Location
    San francisco
    Posts
    16
    Liked
    7 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by YotaDan View Post
    was just looking for a coil spring with a more progressive spring rate than the stock non TRD coil spring
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
