Question Warning Lights Went Haywire
+ Reply to Thread
Results 1 to 11 of 11
Thread: Warning Lights Went Haywire
  1. #1
    Lurking Member hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some. hmayasi has done just about everything...and then some.
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Default Warning Lights Went Haywire
    My instrument cluster just went haywire. All the warning lights are on including the check engine light. The 4-Lo light is flashing rapidly. I want to say that I read in a post a long time ago that this might happen when you blow a fuse. I just cannot find that post for the life of me. If it is a fuse, which fuse would cause all this?
    Open to other suggestions.
  2. #2
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,581
    Liked
    197 times
    Images
    8
    Rep Power
    32267
    Default Re: Warning Lights Went Haywire
    I suspect that it's something more than a fuse, but I guess anything is possible. Maybe these will help.
    lights.pdf
    tundra-fuses-by-system.pdf
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  3. #3
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Thread Starter
    What is the air pump and what does it do? I remember I used to hear it right after startup and now I don't. One of the reasons for those lights seems to be the air pump.
    Check engine light : on
    VSC light: blinking
    Traction control light: on
    4-Lo light: blinking.
    Thanks for the PDF's.
    Sent from AutoGuide.com Free App
  4. #4
    Rookie nickleuci is on a distinguished road.
    Join Date
    Nov 2007
    Location
    weare, nh
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I have the same problem, just happened tonight. Anybody know what could cause this?
  5. #5
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,581
    Liked
    197 times
    Images
    8
    Rep Power
    32267
    Quote Originally Posted by hmayasi View Post
    VSC light: blinking
    The bad news ............... it sounds like you have an AIP problem. (air pumps and valves)
    The good news ............. it is under warranty!
    AIP Warranty Extension from Toyota
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Scangauge II
    Techstream
    CBTMA member
    Block Off Plate
  6. #6
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Thread Starter
    Thanks. I just called the dealer and scheduled an appointment to take it in. My truck just turned 60K (60,055 actually). So I hope this means it is still covered. And if not, I did purchase the extended warranty with it, so hopefully that will cover it. Is there anything else I can mention to them to take care of since I will be taking it in anyways? Any other recalls or TSBs?
    Thanks.
  7. #7
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,581
    Liked
    197 times
    Images
    8
    Rep Power
    32267
    Toyota will have a complete list of all recalls for your truck. I suggest that you DO NOT LET THEM DO THE GAS PEDAL RECALL!
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Scangauge II
    Techstream
    CBTMA member
    Block Off Plate
  8. #8
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Thread Starter
    Too late. The previous owner apparently had that done. I still think its jumpy though, and that's fine with me.
  9. #9
    Lurking Member s_srobertson is on a distinguished road. s_srobertson's Avatar
    Join Date
    Nov 2008
    Location
    Santa Fe, NM
    Posts
    43
    Liked
    0 times
    Images
    6
    Rep Power
    5
    Have you recently wired aything into youre truck, i.e. topper? Lights?
    2008 Tundra DC
    OME MD Coils, Airlift Airbags
    305/65r18 BFG All Terrain
    ARE Topper
  10. #10
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Thread Starter
    I installed the OEM factory JBL nav unit. That's the first thing I thought too. So I checked every fuse in the truck and they all seem to be ok. I printed out the TSB and took it to the dealership. We'll see what they say.
    Do you have any ideas?
  11. #11
    Join Date
    Aug 2012
    Location
    United States
    Posts
    31
    Liked
    0 times
    Rep Power
    796
    Thread Starter
    Well, got a call from the dealer that the truck was ready. As soon as I get in the truck the damn lights turn on again. I asked what they did, and they said they cleared the code and drove it around for a little bit and it was ok. They didn't do the TSB AIP fix since it wasn't generating the correct code for it. Apparently, it was throwing a speed sensor code. So now I am thinking this has something to do with the nav install that just happened. I have no idea where to start troubleshooting and what it is I need to be investigating. Also, the weird thing is, I don't hear that air pump after startup. I used to hear it every morning, in fact, I would wait to hear it before putting my truck in reverse and taking off to work. It was like signal for me that the truck was ready. And now I don't hear it all. So either they are lying, or they are telling the truth and somehow that code is also somehow related to the damn air pump.
    I am really lost guys. I seriously need your help. Any electrical gurus out there that want to help?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
