Parking brake?
+ Reply to Thread
Results 1 to 8 of 8
Thread: Parking brake?
  1. #1
    Supercharged Member italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88 likes to be on top. italiantundra88's Avatar
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    24
    Posts
    2,122
    Liked
    304 times
    Images
    10
    Rep Power
    11569
    Default Parking brake?
    I got in my truck the other day and was playing with my parking brake. I notice it went to the floor quite easily. I then realized by putting it in drive an the truck moving that it is non existent. The pedal is fine the dash indicator works it just doesn't stop the truck. Is there am adjustment, is the cable busted where should I start?
    07 Tundra Limited DC 5.7 TRD Off Road
    All interior leds, and led reverse lights, black headlight mod, morimoto mini H1 projector retrofit with 5000k hids 5000k 55w hid fogs, debadged, 2010 sport color matching grill, 2 sundown sd 10s in a fox under seat box, afe stage 2 cold air intake, super 44 flowmasters dumped after rear axel
    http://www.tundrasolutions.com/forum...store-coupons/ GOOD STUFF IN HERE
    Quote Originally Posted by oofy15354 View Post
    she got mad when i came home and sat in the truck before going inside to see her... i guess the tundra just requires less money and maintenance.....
    Quote Originally Posted by tundrunk View Post
    The sad part is, when I googled "blowmaster" images a picture of my truck comes up, fail.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member wawagoosie is on a distinguished road.
    Join Date
    Apr 2008
    Location
    Wawa
    Posts
    120
    Liked
    1 times
    Rep Power
    6
    Default Re: Parking brake?
    There is an adjustment to tighten cable, driver's side approx behind passenger door, it is probably rusted, you'll need to soak it in lube
  4. #3
    Junior Member mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard's Avatar
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    399
    Liked
    38 times
    Rep Power
    41
    Kroil = lifesaver. Well, nut and bolt saver to be exact. And knuckle saver.
    Penetrating-Lubricating Oils
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow.
  5. #4
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    24
    Posts
    2,122
    Liked
    304 times
    Images
    10
    Rep Power
    11569
    Thread Starter
    Thats guys. Is it an obvious adjustment nut or is it by anything else that I could confuse it with.
  6. #5
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    399
    Liked
    38 times
    Rep Power
    41
    Just don't mistake it for the machine gun deployment nut. Been there, done that. In the garage. It was a mess.
  7. #6
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    24
    Posts
    2,122
    Liked
    304 times
    Images
    10
    Rep Power
    11569
    Thread Starter
    Quote Originally Posted by mattjgerard View Post
    Lol I wanted to make sure cuz on my first gen (even tho I'm experienced at doing my own oil) I almost drained the tranny cuz the oil pan was under the skid plate.
    Now I did find it and I think it's adjusted properly. The bracket moves and and can't go any further once the brake is all the way to the floor. I think I might have something up in the rear brakes. Which makes me concerned. If the parking brake isn't functioning properly are the actual brakes functioning properly? Is the parking brake separate. On day I'm going to have to jack up the rear end and check.
  8. #7
    Junior Member NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future. NickBrewer has a brilliant future.
    Join Date
    Jan 2007
    Location
    Wasilla, AK
    Posts
    498
    Liked
    9 times
    Rep Power
    112
    Usually on a vehicle with 4 wheel disk brakes, the parking brake is implemented separately, usually with a small drum brake. This is how the Tundra is setup, also the main brake system is hydraulically actuated, where the parking brake is actuated by a cable, so two completely different systems....
    Nick Brewer
    NickBrewer@msn.com
    2007 Toyota Tundra RCSB 5.7L
    1986 Yamaha SRX-6
    2013 Yamaha XTZ1200D Super Tenere
  9. #8
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    24
    Posts
    2,122
    Liked
    304 times
    Images
    10
    Rep Power
    11569
    Thread Starter
    Quote Originally Posted by NickBrewer View Post
    I knew the brake was hydrollic but maybe the cable worked it some how. Wasn't sure. I know a little about cars but that makes me feel better about the fuctionality of my rear brakes. I'm honestly not to worried about it. Literally the only times I ever used my parking brake was when I was too lazy to put the truck in park at the drive throughs so.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
