Alternator removal trouble!
+ Reply to Thread
Results 1 to 7 of 7
Thread: Alternator removal trouble!
  1. #1
    Rookie SFTUNDRA08 is on a distinguished road.
    Join Date
    May 2011
    Location
    key largo
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Default Alternator removal trouble!
    So i decided to take on the task of replacing my alternator myself in order to avoid crazy dealership fees ($1400).
    Once i finally got the damn skid plate off, i started on the alternator removal process. But everytime i go to loosen the bolts, i end up turning the whole pulley mechinism. I fell like im missing a step. Any advice???
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64 is a name known to all. Art64's Avatar
    Join Date
    Jul 2006
    Location
    Perris, CA
    Posts
    1,400
    Liked
    2 times
    Rep Power
    282
    Default Re: Alternator removal trouble!
  4. #3
    Junior Member teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin is a pinnacle in their own mind. teallin's Avatar
    Join Date
    Aug 2010
    Location
    Bloomfield NJ
    Posts
    335
    Liked
    27 times
    Images
    7
    Rep Power
    2243
    You usually don't remove the pulley untill the altenator is out of the truck, then you hold the pulley and use an impact wrench to remove the nut.
    2010 Black Rock Warrior DC
    mpg buttons added
    WeatherTech Side Window Deflectors
  5. #4
    Join Date
    May 2011
    Location
    key largo
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    i dont know if i started on the wrong bolt or not, but i used a socket wrench to try and loosen the bolt, and all im doing is turning the whole pulley system
  6. #5
    Join Date
    May 2011
    Location
    key largo
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    this was the best step by step process i have seen yet. THANKS
  7. #6
    Join Date
    Jul 2006
    Location
    Perris, CA
    Posts
    1,400
    Liked
    2 times
    Rep Power
    282
    I believe there is only 1 bolt holding the front of the alternator. that bolt also serves as the hinge. It's hard to see due to tight space. I had to use my iphone to video the front of the alternator to I can tell what bolt to loosen up.
  8. #7
    Junior Member Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage is a glorious beacon of light. Afterimage's Avatar
    Join Date
    Mar 2007
    Location
    Pierce County, WA
    Posts
    171
    Liked
    8 times
    Rep Power
    198
    Toyota has a special tool to hold the pulley while removing/installing the pulley nut.
    Otherwise, here is some further reference.
    Attached Thumbnails Attached Thumbnails Alternator removal trouble!-1.jpg   Alternator removal trouble!-2.jpg   Alternator removal trouble!-3.jpg   Alternator removal trouble!-4.jpg   Alternator removal trouble!-5.jpg   Alternator removal trouble!-6.jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
