HELP!!! How to improve MPG on my Tundra
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Like Tree20Likes
Thread: HELP!!! How to improve MPG on my Tundra
  1. #1
    Join Date
    Jul 2013
    Location
    erath la.
    Posts
    7
    Liked
    3 times
    Rep Power
    0
    Default HELP!!! How to improve MPG on my Tundra
    I Have a 2013 Tundra with a 6" procomp suspension lift with 35"x 12.5 x 20 tires and my gas millage is horrible.I'm getting about 200 miles to the tank which adverages about 10MPG. Is there anyone out there that can tell me how to improve it without removing the tires and lift?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member bschroeder27's Avatar
    Join Date
    Apr 2013
    Location
    Newfoundland, Canada
    Posts
    331
    Liked
    183 times
    Images
    1
    Rep Power
    45243
    Default Re: HELP!!! How to improve MPG on my Tundra
    There are many options to increase MPG and countless threads explaining the pros and cons of each mod. Use the search feature on this site and read up a little!
    - Don't run your fingers over my truck... And I won't run my truck over your fingers!!
  4. #3
    Join Date
    Dec 2005
    Location
    Mechanicsburg, PA
    Posts
    414
    Liked
    87 times
    Rep Power
    3747
    Has your odometer / speedometer been adjusted for the change in tire size? If you are calculating miles per gallon, and your odometer is off, you are getting bad information.
    MaylonTRD and 9rider like this.
    2013 Tundra DC 4X2 4.6l Silver Sky Metallic
    2010 Camry
    2000 Echo
  5. #4
    Join Date
    Jan 2008
    Location
    Illinois
    Posts
    286
    Liked
    45 times
    Rep Power
    3156
    Remove the lift and oversized tires.
    __________________________________________
    2013 Barcelona Red Tundra Double Cab SR5 4X4 5.7
  6. #5
    Mark it eight, Dude... MaylonTRD's Avatar
    Join Date
    Oct 2007
    Location
    Shreveport,LA
    Posts
    4,373
    Liked
    125 times
    Images
    35
    Rep Power
    86844
    I have a lift and larger tires and I get better than 10. Are the miles all city like stop and go, or any interstate? I would say I get between 12-14 in the city and about 18-19 on the interstate but I have to keep the speed around 70. Do you drive aggressively or try to get better mileage?
    2014 4Runner Limited Blizzard Pearl- Wife's
    2014 Tundra CM SR5 5.7l TSS Edition Magnetic Gray ProComp 6", XD809 18x9 -12 offset, trail grappler 35x12.50
    2007 Tundra CM SR5 5.7 2WD TRD Slate SOLD
    Skyjacker 6" lift, BFG KO 305/65R18 (33.7"x12.2") XD Hoss Chrome 18x9 +30 offset, Go Rhino Dominator II Nerf Bars, Debadged, AFE Pro Dry Drop-in Craven Speed Stubby Antenna, HomeLink Rear View Mirror, Ranch Hand Grille Guard, Custom Spintech Muffler, Pioneer head unit, RF shallow mount sub, Hypertech Speedo Calibrator
  7. #6
    Junior Member Tundra-Rebel's Avatar
    Join Date
    Feb 2013
    Location
    Texas
    Posts
    238
    Liked
    154 times
    Rep Power
    38886
    The best way to increase the mileage is to drive your wifes Corolla.
    VC-17, Paul312612 and farkleboy like this.
  8. #7
    Veteran Member farkleboy's Avatar
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    517
    Liked
    62 times
    Rep Power
    272
    Quote Originally Posted by Tundra-Rebel View Post
    I ride my motorcycle. Even at 30mpg (which is a little low for a bike) its twice the mpg's as the tundy. Now, just to get some studded tires for winter.
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow.
  9. #8
    Junior Member 9rider's Avatar
    Join Date
    Jun 2011
    Location
    Southern California
    Posts
    345
    Liked
    20 times
    Images
    3
    Rep Power
    926
    Fab some sheet metal and install along side your under cab and trunk will help keep wind drag down. I am thinking of this but have no time and how to start the project yet. Or remove the carbon filter, Myth , work or not maybe but it did me no harm beside Mother Earth so I remove it.
    windtunnel likes this.
  10. #9
    Join Date
    Dec 2004
    Location
    MASS
    Posts
    159
    Liked
    26 times
    Rep Power
    2570
    Some 2012-2013 Tundras have had problems with their ECMs which causes poor gas milage.
    Look in the sticky threads under TSBs. The dealer has to recalibrate the ecm.
    It could be the problem. Did you have such bad mpgs before the mods were done?
  11. #10
    Join Date
    Sep 2012
    Location
    USA
    Posts
    94
    Liked
    22 times
    Rep Power
    2128
    Quote Originally Posted by brockbenoit View Post
    Mais yeah trow dem steel toes out and put on your Delcambre Reeboks to lighten da load, and drive da speed limit on Highway 14.
    1995 T-100 250,000 miles and still going strong!
    2012 Tundra CrewMax 4.6w/Tow.Pkg.
  12. #11
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    517
    Liked
    62 times
    Rep Power
    272
    Anything over 65 will suck gas, especially with upped wheels and lift. Get a GPS to see if your speedo is off and therefore throwing off your calculations. Try to find some non-ethanol fuel. Take any extra load out, don't carry more weight than you have to.
    And release the e-brake
    Sent from AutoGuide.com Free App
  13. #12
    Junior Member Sean266's Avatar
    Join Date
    May 2012
    Location
    Denver, CO
    Posts
    139
    Liked
    13 times
    Rep Power
    4
    I have 35" and I get about 13MPG...I also purchased a hypertech programmer to ensure its reading correctly
    Sent from AutoGuide.com App
    MaylonTRD and brockbenoit like this.
  14. #13
    Join Date
    Jul 2013
    Location
    erath la.
    Posts
    7
    Liked
    3 times
    Rep Power
    0
    Thread Starter
    Yes the Odometer is off when you get to about 50mph its off about 4mph. I downloaded a app on my phone that has a tripometer on it and i relized every 12 miles i go i lose 1 mile.That could be a big part of the problem i'm really going more miles than what the tripometer is saying. Have you ever heard of anyone fixing the speedometer cause the person I talked to at the dealer said that toyotas cant be fixed I thought he was blowing smoke up my ass..
  15. #14
    Join Date
    Oct 2007
    Location
    Shreveport,LA
    Posts
    4,373
    Liked
    125 times
    Images
    35
    Rep Power
    86844
    Hypertech speedometer calibrator
  16. #15
    Join Date
    Jul 2013
    Location
    erath la.
    Posts
    7
    Liked
    3 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by MaylonTRD View Post
    Thanks alot I will research to see where to find one and how to do it
    MaylonTRD likes this.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
