2009 tundra trailer wiring
+ Reply to Thread
Results 1 to 4 of 4
Thread: 2009 tundra trailer wiring
  1. #1
    Rookie dietdewboy's Avatar
    Join Date
    May 2009
    Location
    WI.
    Posts
    6
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Default 2009 tundra trailer wiring
    I have a 2009 Tundra Rock Warrior 4x4, didn't come with a tow package, has a factory 4-pin connector.
    Is there a way to convert this to a fully functional 7 pin system?
    The local trailer shops are giving me fits
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    May 2008
    Location
    Bucks county
    Posts
    51
    Liked
    1 times
    Thanks
    0
    Rep Power
    1195
    Default Re: 2009 tundra trailer wiring
    just get a plug adapter,problem solved
  4. #3
    Join Date
    May 2009
    Location
    WI.
    Posts
    6
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    I'm trying to make it fully functional, back up lights, 12v power all the above
  5. #4
    Veteran Member FL_Tundra's Avatar
    Join Date
    Dec 2007
    Location
    West Central, FL
    Posts
    1,241
    Liked
    209 times
    Thanks
    0
    Rep Power
    9713
    Towing Options, 7 Pin Wire Harness - 2008 Toyota Tundra
    http://www.trdsparks.com/install/08951-65001inst.pdf
    This is all that I could find for the Tundra without the tow package. Looks like a lot of work. Good luck.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
