LinkBack (14) Thread Tools Display Modes
  6 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-28-2005, 08:11 PM
Dealer : Anchor Motors
2006 Toyota Tacoma access cab- offroad
Last Online: 11-05-2009 06:00 PM
bennicde is on a distinguished road.
bennicde's Photo Albums
Default 2007 Toyota Tundra Complete
A toyota salesperson told me yesterday that he was at a meeting and learned the following,
The new tundra will be available next spring with a 5.4 L V-8 and 10,000 lbs towing ability. no diesel until a few more years and the truck will be much bigger.
Old 09-29-2005, 09:24 AM
rayman's Avatar
Dealer : Hoselton Toyota Scion
2002 Toyota Tundra,
2009 Toyota Corolla
Last Online: 10-22-2009 11:19 AM
rayman is on a distinguished road.
rayman's Photo Albums
Next spring....hmmmm....didn't think it would be that early.
Can anyone else confirm this? I won't likely trade in right away, but I am anxious to see the bigger Tundra.
And we need more spy shots ....
2002 Tundra Access Cab SR5 V8 4x4 TRD Donahoe Racing adjustable coilover shocks, Total Chaos Fabrication 1” Diff. Drop Spacer, Bilstein 5100 Series shocks, Downey add-a-leafs, Mickey Thompson 16X8 Classic II wheels, Mickey Thompson LT265/75R16 Baja Radial MTX tires, Cooper LT265/75R16 Discoverer M+S tires (for winter), K&N air filter, Westin Signature Series Step Bars, A.R.E. MX Series truck cap, LINE-X spray-on bedliner, AMP Research Bedxtender, DuraHitcH trailer hitch, Warn front receiver, front tow hooks, Auto Ventshade Ventvisors, Husky Floor Liners front & rear, General Lee 10 Meter radio, Astatic mic, Nemarc M-1S CB Console, Wilson 1000 CB antenna
2003 Sunline Solaris T-2363 Basically stock
Old 09-29-2005, 09:31 AM
brandkd's Avatar
Dealer : Sierra Toyota
2005 Toyota Tundra
Last Online: 05-09-2008 01:54 AM
brandkd is on a distinguished road.
brandkd's Photo Albums
If those come out in 2007, it's probably best to wait a couple of years so they work out all the bugs. I have a friend that bought a Titan the first year they came out and rue's the day.
2005 Tundra SR5 DC TRD Package
Phantom Grey Pearl
Flowmaster Exhaust
K & N Filter
Westin Nerf Bars
MB Razor Wheels
Old 09-29-2005, 09:43 AM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 11-02-2009 08:38 PM
AGREED!
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 09-29-2005, 12:57 PM
scottfraser's Avatar
Dealer : George Jackson Toyota
Last Online: 01-28-2007 08:33 PM
scottfraser is on a distinguished road.
scottfraser's Photo Albums
I did not think the new San Antonio plant where the new Tundra will be built will be in production until July/Aug time frame next year? Unless they are going to make a run of 07 tundras in the existing plant?
Scott
2000 Tundra Limited, ARE Z Series Cap, AAL,Bilsteins, Cornfed 2.5" front lift, BFG 265x75x16 KO's, Garmin GPSMAP 265, JVC disc/MP3 player, Reese Electric Brake Controller Helwig rear sway bar.
Old 09-29-2005, 01:16 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I really doubt that the present Tundra chassis can safely control a 5 ton trailer. I'd want a long wheelbase 3/4-ton truck for that trailer and an engine bigger than 5.4L.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 09-29-2005, 02:45 PM
ricqik's Avatar
Last Online: 10-24-2009 01:53 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
You guys forgetting something. Remember that when the tundra first came out it had the strongest frame as I remembered toyota claimed. Back then the domestics are already rated to tow more, well into the 8k range, even with a weaker frame. It wasn't until the past few years that everyone upgrade to boxed frame, only then did they have a stronger frame and not by much. Well, I wouldn't call it stonger, just more rigid. Rigid doesn't always mean strength, why else would semi's not have rigid frames. You don't want to snap a frame cuz it won't flex to absorb the torque. Currently it's not the frame I'm worried about, it's the bearings, brakes, axles, gears, and it's light weight.
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 09-29-2005, 03:29 PM
krodad's Avatar
Dealer : Wilson Oldsmobile Cadillac Toyota
2005 Toyota Tundra
Last Online: 07-22-2007 01:23 AM
krodad is on a distinguished road.
krodad's Photo Albums
Absolutely correct... there are a lot of things that make a great towing truck handle the loads, and most of them, just as you mentioned, are not conducive to a plush ride. Most of these also move in various degrees with the suspension. Also as you mentioned, big wheel bearings are a must if there is going to be a heavy tongue load, so long hops with a heavy load in the Tundra is not a wise idea.
I used to drive around in a F350 and F550 which rode like bricks, but they could pull anything. I'd put a full ton on the flatbed when driving "without load" just to soften things up A BIT. Nobody wants this for daily driving though, so we compromise.
My Tundra is great, but even pretty lightweight enclosed trailer bogs her down due to the wind resistance. The 4.7 is nice, but when it comes to towing, it's kind of a pooch. Don't think I'd ever consider pulling even 8000lbs even if it was rated for it. Big displacement diesel if you do this a lot.
Old 09-29-2005, 11:07 PM
Dealer : Funk's Toyota
2005 Toyota Tundra
Last Online: 11-05-2009 09:10 PM
Diego is on a distinguished road.
Diego's Photo Albums
As far as I know they are planning a totally new redesign of the new Tundra or whatever they are going to call it and it is said to be larger and much beefier to handle the extra towing capacity. The whole truck is supposed to be bigger than the current Tundra. I don't think they were just planning to beef up the frame a little in the regular Tundra and call it a new heavy duty model but I guess we will find out when it comes out. Kind of curious what the HP and torque fugures will be as well as the gas mileage.
Old 09-30-2005, 07:24 AM
Originally Posted by Diego
As far asco I know they are planning a totally new redesign of the new Tundra or whatever they are going to call it and it is said to be larger and much beefier to handle the extra towing capacity. The whole truck is supposed to be bigger than the current Tundra. I don't think they were just planning to beef up the frame a little in the regular Tundra and call it a new heavy duty model but I guess we will find out when it comes out. Kind of curious what the HP and torque fugures will be as well as the gas mileage.
If Toyota is able to continue with bigger engine, more power, better gas mileage as they did in the past in the tacoma, maybe the new tundra will give much better gas mileagethan the current one. Lets's hope
Old 09-30-2005, 03:13 PM
The question is does Toyota think there is a big enough market at this point in time for a large 1 ton pickup. I think that will decide wheather they jump in with both feet. If they think the market is softening up , I think we will see somehting like the new f150, which is more/less the same as the old f150 but dressed up to look like a bigger tougher truck. If they think the market is truly strong, then we will see a true heavy duty work truck from the bottom up. Toyota have been making medium/heavy duty work trucks forever in other markets, they certainly have the experience. The other thing which must concern them is the price. Toyota typically can demand a premium for there trucks, I will assume that a lot of the F250/F350 type trucks are leased by contractors, especially in the fall when the last year stock is dumped. It might be hard to justify $5-10k for a toyota over a 36-48 month lease.
Old 09-30-2005, 10:59 PM
Dealer : Exeter Toyota
2005 Toyota Tundra,
- Other - 2005 Touareg V8,
2001 Toyota Tundra,
Last Online: 10-30-2009 07:16 AM
Cropdoc is on a distinguished road.
Cropdoc's Photo Albums
Default 2007 Tundra engine.
My dealer was out west and saw it.
5.7 L V-8 with 400 hp.
It's a full size truck.
4.7 L is still available.
I ain't happy about the bigger size truck.
Wonder if the 5.7 L will fit in my 2005 engine bay?
This habit is worse than drugs ...............
Old 10-01-2005, 12:18 AM
TundraTRX's Avatar
Dealer : Desert Toyota Scion Of Tucson
2003 Toyota Tundra
Last Online: 11-03-2005 01:50 AM
TundraTRX is on a distinguished road.
Send a message via AIM to TundraTRX Send a message via MSN to TundraTRX TundraTRX's Photo Albums
I hope the "new" truck is a bit bigger, but still manageable and "fuel efficient." Its nice they are keeping the 4.7 (Cropdoc). I wonder what displacement the rumored hybrid engine will be available in, and if it will truly perform as Toyota has hyped. That is the engine I'm interested because I predominantly use my truck as my daily commuter.
My ePinions Review on the 2003 Tundra:
http://www.epinions.com/content_136168771204
MY TUNDRA: Desert Sand Mica, 2003 SR5 Toyota Tundra Access Cab, with (debadged) TRD Off-Road Package.
CURRENT ADD-ONS, BOLT-ONS, SLAP-INS & MODIFICATIONS:
EXTERNAL: Toyota of Dallas Sports Grille, Performance Products bed mat, PIAA silicon wiper blades, Sylvania Silverstar headlight bulbs, Bully stainless steel nerf bars, debadged of all labels & insignias externally, Stant 10509 locking gas cap/cover, bullet style valve stem covers, OEM Tow Package (130A alternator, transmission cooler, etc.), 2" blind spot mirrors (Wal-Mart parking lot aids), 12" stubbie antenna, color-keyed door edge trim, clear front corners.
INTERNAL: OEM dash cover, super white/blue xenon interior lights (look awesome at night), Wheelskins sand colored steering wheel cover, OBX sports pedals, map light mod, Tundra labeled door sill protectors.
And, a lot more to come!
All I have to do now is invest in the Redneck Retirement System*, then I can finish with all the modifications I want on my truck.
* - Redneck Retirement System: Winning the State Lottery.
Old 10-01-2005, 02:08 AM
Dealer : Moultrie Toyota
2005 Toyota Tundra
Last Online: 10-28-2007 07:33 PM
docsg is on a distinguished road.
docsg's Photo Albums
I had an 03' SR5 TRD and sold it and bought an 05' (identical in color and model with a couple of extra features like factory tow package instead of distributor installed tow package). I am calling my dealer soon and see what he thinks I can get a late 06' for if the 07' comes out early as someone reported. I will retail the 05' myself as they sell for high $$ and fast. I have had zero problems with the 05' as well as the 03' and would expect the 06' to be about as defect free as it could be after 6 years. And, I love the design and size of the current Tundras. After that I would probably wait until late 08' or 09' to trade again (assuming we can even afford to drive a truck by then!).
Old 10-01-2005, 02:22 AM
Dealer : Bailey Toyota
2005 Toyota Tacoma,
2007 Toyota FJ Cruiser
Last Online: 02-24-2008 07:51 PM
tbrown78 is on a distinguished road.
tbrown78's Photo Albums
If there's one thing I've learned about sales people it's that they're almost never right. I heard a million and one different things about the 05 tacoma before it was released and almost all of what the dealers told me was false. One dealer told me it had a spray in bed liner, same dealer told me it was going to have a V8 option, another told me it was going to be the same size as the last gen with a lot more power. These guys know nothing, and Toyota knows not to trust them with any real info because they're all meat heads. The real truth will be revealed when the truck is released. Until then it's all speculation.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/46139-2007-toyota-tundra-complete/
Posted By For Type Date
2005 Dodge Stratus Sxt Factory Stereo, 2005 Dodge Ram 1500 Towing Capacity, 2005 Dodge Viper Performance - Angularkinetics This thread Refback 03-08-2009 10:43 AM
Auto Ventshade Stepshield, Auto Ventshade, Auto Water Pump Service - Laverdausa This thread Refback 03-08-2009 08:28 AM
Lexus Es330 Floor Mat, Lexus Es330, Lexus Es350 Acceleration Problem - Avantisedan This thread Refback 03-08-2009 07:01 AM
87 Nissan 300Zx, 87 Monte Carlo Electrical Diagram, 87 Nissan Sentra - Illusionillustrations This thread Refback 03-08-2009 06:45 AM
2005 Ford F150 Pick Up Truck, 2005 Ford Explorer Sport Trac Xlt Bed Cover, 2005 Ford F150 Recalls - Carbadges This thread Refback 03-08-2009 04:46 AM
Mazda Infiniti, Mazda Headlight Replacement, Mazda Keys Denver Colorado - B2600 This thread Refback 03-08-2009 04:40 AM
Honda Ridgeline Tail Trim, Honda Ridgeline Specs, Honda Ridgeline Tonneau Covers - Psiatk This thread Refback 03-07-2009 04:26 AM
Wrap Jeep Header, Wrangler Original Cargo Pants, Wrecked 1997 Nissan Sentra For Sale - Victory8Ball This thread Refback 03-06-2009 04:08 AM
Custom Grille For 08 Gmc Hd, Custom Grille Chevrolet Malibu Ls, Custom Hawaiian Print Car Seat Covers - Aftermarketheadlights This thread Refback 03-06-2009 03:41 AM
Tundra Solutions is where you can research, discuss, price and repair your Toyota, Scion or Lexus This thread Refback 04-10-2007 11:33 AM
[www.buschtaxi.de] - Thema anzeigen - 2007 Full-Size Tundra Post #491 Refback 01-22-2007 01:18 PM
is my 2005 lexus es330 bluetooth enabled This thread Refback 12-29-2006 10:23 PM
2007 tundra - 2007 swicki - powered by eurekster This thread Refback 11-22-2006 10:01 AM
Re: 2007 Tundra This thread Refback 11-07-2006 07:38 PM
Rebates for Sept??? deadeye01 1Gen-Tundra 9 09-01-2006 03:38 PM
