20" vs. 18" wheels?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: 20" vs. 18" wheels?
  1. #1
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    389
    Liked
    0 times
    Rep Power
    50
    Question 20" vs. 18" wheels?
    Folks,
    Wondering what the difference is going with 20" wheels vs. 18" in terms of use. I prefer the 18" but I can get a 5.7 LTD w/ NAV now with 20". I'm assuming the higher sidewall of the 18" will be better for off-road use. I'm told 20" are becoming more 'standard' on bigger trucks, whatever that means.
    Personally I think the 20s look a little pimpish. Is it big enough of a difference to wait 4-6 weeks? Also, the 20" versions are without TRD...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Oct 2005
    Location
    Boulder,co
    Posts
    639
    Liked
    3 times
    Images
    4
    Rep Power
    14
    Default Re: 20" vs. 18" wheels?
    20" will have a stiffer ride than 18" because there would be overall less tire, also with 20" wheels you will find the tires are usually more expensive.... a lot of it has to do with looks now, instead of ride, like i enjoy 18" wheels more because they feel a lot smoother than a 20. also i dont care for the TRD package, its way too much money for what little you get. but thats just my $.02
  4. #3
    Veteran Member StatCoder's Avatar
    Join Date
    Jan 2007
    Location
    Austin, TX
    Posts
    1,577
    Liked
    5 times
    Rep Power
    123
    Quote Originally Posted by sic402 View Post
    I would say this begs the question but that isn't a correct usage of this term.
    However, it raises the question of why 20" tires are more expensive when there is overall less tire?
  5. #4
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    389
    Liked
    0 times
    Rep Power
    50
    Thread Starter
    Quote Originally Posted by StatCoder View Post
    Tire manufacturers are behind on 18, 19 and 20" tires I'm told which is the only reason they are more expensive.
  6. #5
    Veteran Member Cooper S's Avatar
    Join Date
    Feb 2007
    Location
    Fredericksburg, VA
    Posts
    528
    Liked
    2 times
    Rep Power
    9
    I have the 20's on mine and love them. In trucks, I like seeing the wheel actually fill the wheel-well and not see a lot of empty space.
    ___________________
    07 Toyota Tundra Limited DC
    4x4, 5.7L, Red Rock Leather
    Cold Weather Package, Remote Start,
    20" wheels, DVD NAV w/Bluetooth, Rear DVD w/10" screen, Formula 1 Tint, Access Tonneau Cover, TRD Dual Exhaust, WeatherTech Floormats
    http://www.flickr.com/photos/jdimetal - 2/27/07
    06 MINI Cooper S SB Checkmate
    15% Reduction Pulley, HDI
    22mm Rear Sway, Custom ECU
  7. #6
    Junior Member dogger's Avatar
    Join Date
    Mar 2002
    Location
    Mt Juliet, TN
    Posts
    133
    Liked
    0 times
    Images
    6
    Rep Power
    14
    There isn't overall less tire, there is just less sidewall. Check any tire
    pricing guide - as the aspect ratios go down, the price goes up.
    dogger
  8. #7
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    389
    Liked
    0 times
    Rep Power
    50
    Thread Starter
    What about effects of the heavier wheel on acceleration and mpgs? That's my main concern. Also wondering why all but one of the option packages include the 20" wheels. Am I making too big of a deal outta this? The thing is for less money on the package you get NAV, 18" with TRD and running boards. For the 20" wheel NAV package that's all you get, no TRD and no running boards. Seems like a no brainer to me to stick with the 18s unless I'm missing something, help me out someone!
  9. #8
    Join Date
    Feb 2007
    Location
    Jackson, MS
    Posts
    435
    Liked
    2 times
    Rep Power
    9
    Quote Originally Posted by Cooper S View Post
    Someone correct me if I'm wrong, but when I compare photos of trucks equipped with 18 and 20 inchers, it doesn't look like the wheel well space differs. The 18 inchers have more tire around the wheel (taller sidewalls), whereas the 20 inchers have a noticeably larger wheel size but overall it fills up the same space considering the lower profile of the tire.
  10. #9
    Junior Member KNABORES's Avatar
    Join Date
    Feb 2006
    Location
    Cabot, AR
    Posts
    207
    Liked
    2 times
    Images
    15
    Rep Power
    10
    overall diameter will be roughly the same. its called plus one sizing or in this case plus two sizing. as you increase the rim diameter you decrease the sidewall profile to compensate. some 20" rim designs will be more likely to bend than smaller diameter due to the materials and the distance between spokes that reinforce the rim. Bigger rims means you can fit larger diameter brakes which is why 18" are now standard on tundra. you wont be able to put 16" on the trucks. larger diameter tires are more expensive because the volume sold is lower. although the seem popular, a majority of people still have 15" - 17" tires on there cars especially the most popular models, camry, accord etc.
  11. #10
    Join Date
    Jan 2006
    Location
    Santa Rosa, CA
    Posts
    173
    Liked
    0 times
    Rep Power
    10
    There is no reason to go with 20 inch wheels. It's just the "flash factor". If you don't care about the bling, then get the 18"s. That's the way I'd go.
    2006 Tundra DC Limited TRD
    1987 4Runner with SAS
  12. #11
    Lurking Member GATORS_75's Avatar
    Join Date
    Feb 2007
    Location
    J-Ville
    Posts
    47
    Liked
    0 times
    Rep Power
    9
    I have 20" wheels and love them. I went with 20's because I have a 2WD and didn't like all of the wheel gap. However, your stock brakes are set up for 16" to 17" wheels so you might be changing your brakes a little more frequently. I just hit 30k and haven't had to change my brakes yet. I didn't see any changes in the speedometer either. Just keep them rotated and balanced every 5K and they will last!
    [SIGPIC]
    2005 TUNDRA SR5 AC
    20" Helo Kick's wrapped in 275/45R General Grabbers
    15% Tint all around
  13. #12
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    389
    Liked
    0 times
    Rep Power
    50
    Thread Starter
    Quote Originally Posted by Schly View Post
    Is there an issue putting an 18" rims on a 07 Tundra that came with 20" rims? Odometer, breaks, etc.?
  14. #13
    Junior Member OneOfTheSick's Avatar
    Join Date
    Jun 2006
    Location
    Fort Mill, SC
    Age
    30
    Posts
    125
    Liked
    0 times
    Images
    7
    Rep Power
    9
    Quote Originally Posted by mtnrunner View Post
    As long as you have to proper size tire there will be no problems since they have very close to the same overall diameter. I compared the tire sizes/rim combos that Toyota is offering a while ago and they are all within .5% of each other in terms of overall diameter.
  15. #14
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    389
    Liked
    0 times
    Rep Power
    50
    Thread Starter
    Quote Originally Posted by OneOfTheSick View Post
    Thanks, the 5.7 LTD DC w/ 20s sold so I'm back to looking for the right truck again, it's painful. Really want the TRD with NAV and 18s as it's the least expensive NAV option. Plus you get the running boards.
  16. #15
    Join Date
    Feb 2006
    Location
    Tempe, AZ
    Posts
    148
    Liked
    0 times
    Rep Power
    10
    I think you are making the right choice . TRD package is nice and 18" will be better on and off road.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 20" Enkei Deep Six Wheels HELP???
    By mmberry in forum Tires and Wheels
    Last Post: 11-22-2011, 01:20 PM
  2. Wheel Selection FAQ
    By OKCTundra in forum Tires and Wheels
    Last Post: 12-14-2007, 06:26 PM
  3. News|Stories|Photos|Videos
    By Possum in forum Off-Topic
    Last Post: 01-17-2007, 03:36 PM
  4. New 20" wheels and Tires not working HELP''
    By BlackedOut in forum Tires and Wheels
    Last Post: 05-11-2006, 08:09 PM
  5. 18" Boyd Coddington wheels w/ Michelin Pilot LTX's WOW!
    By Champ_87 in forum Tires and Wheels
    Last Post: 04-26-2002, 08:55 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
