Old 02-13-2007, 04:40 PM
LBCBMW's Avatar
Dealer : Power Toyota Cerritos
2001 Toyota Tundra,
2004 Scion xB
Last Online: 10-23-2008 01:43 PM
LBCBMW may have some regrets.
LBCBMW's Photo Albums
Lightbulb More Info On The New 07 Tundra Crewmax
POWERTRAIN/CHASSIS Drivetrain layout Front-engine, RWD or 4WD Engine type 90 V-8, aluminum block Valvetrain DOHC, 4 valves/cyl Displacement 345.6 cu in/5663cc Compression ratio 10.2:1 Power (SAE net) 381 hp @ 5600 rpm Torque (SAE net) 401 lb-ft @ 3600 rpm Weight to power 14.0 lb/hp (13.5 lb/hp, 4x2 Double Cab) Transmission 6-speed automatic Axle/final/ ratio 4.10:1 / 2.41:1 Suspension, front; rear Control arms, coil springs, anti-roll bar; live axle, leaf springs. Steering ratio 18.1:1 (17.3:1, 4x4) Turns lock-to-lock 3.7 Brakes, f;r 13.9-inch vented disc; 13.6-inch vented disc, power assisted, anti-lock, electronic brake distribution, brake assist. Wheels, f;r 20 x 8 in aluminum alloy (CrewMax Limited); 18 x 8 in aluminum alloy Tires, f;r P275/55R20 (CrewMax Limited); P275/65R18 (Double Cab Limited) DIMENSIONS Wheelbase 145.7 in Track, f/r 67.9 in/67.9 in Length x width x height 228.7 x 79.9 x 75.8 (76.0 in, 4x2 Double Cab) Turning circle 44.0 ft Curb weight 5340 lb (4x2 CrewMax), 5145 lb (4x2 Double Cab) Weight dist., f/r n/a% Payload capacity 1525 - 1675 lb (4x2 CrewMax), 1465 -1755 lb (4x2 Double Cab) Towing capacity 10,400 lb (4x2 CrewMax), 10,600 lb(4x2 Double Cab) Seating capacity 5 Headroom, f/r 40.2/38.7 in (CrewMax, Double Cab) Legroom, f/r 42.5/44.5 in (CrewMax); 42.5/34.7 in(Double Cab) Shoulder room, f/r 66.5/65.4 in (CrewMax); 66.6/65.7 in (Double Cab) Pickup box L x W x H 66.7/66.4/22.2 in (CrewMax); 78.7/66.4/22.2 in (Double Cab) Width bet. wheelhouses 50.0 in CONSUMER INFO Base price $n/a Price as tested $n/a Stability/traction control Yes/yes Airbags Dual front, front seat side, front and rear curtain airbags. Basic warranty 3 years/36,000 miles Powertrain warranty 5 years/60,000 miles Roadside assistance None Fuel capacity 26.4 gal EPA city/hwy econ 16/20 mpg Recommended fuel Regular
Old 02-13-2007, 07:27 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: Today 04:03 PM
Images: 10
Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold. Sanosuke is a splendid one to behold.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Default Re: More Info On The New 07 Tundra Crewmax
All this and you couldn't post it in the Toyota Tundra 2007 Complete thread?
Sanosuke!
Tundra CrewMax Reveal - Remarks by Jim Lentz TS Support Toyota, Scion & Lexus News 0 01-07-2007 03:38 PM
Toyota Stages World Debut of All-new 2007 Tundra CrewMax At The 2007 North American.. TS Support Toyota, Scion & Lexus News 0 01-07-2007 03:33 PM
