Old 05-13-2007, 11:12 AM
dsmonline's Avatar
Dealer : Toyota Walnut Creek
2007 Toyota Tundra,
2008 Toyota Highlander Limited
Last Online: 11-17-2009 05:54 PM
dsmonline is on a distinguished road.
dsmonline's Photo Albums
Default ReadyLift Leveling Kit Install (pics)
Installed a ReadyLift leveling kit on my DC yesterday, end result is exactly what I was looking for. Bought the kit from RealTruck for $229.95 minus 7% by using the TundraSolutions promo code TOY, part #66-5075. Took a week to get here, just one small box holding the two strut extensions. Very well made, heavy duty steel and power coated finish.
Install was straight forward, no issues to speak of. Took my brother and I about two hours, however if you plan on installing this yourself, I have several suggestions. First, it is a two person job, trying to do this by yourself would be difficult (but doable). Make sure you have all the tools you will need, there are some required that may not be in the average tool box. Some of those bolts required a very large breaker bar, a standard two footed did not get the job done. Jack stands and a second jack are needed if you do both sides at the same time. Wheel alignment is an must as soon as you are done, the computer readout of my truck before the alignment showed it WAY off. I had the alignment done at a shop that does dozens of lifts a month, so they know what they are doing. Don't expect the alignment to be perfect after the kit, the cams just don't allow for perfect alignment, however everything is in the green.
Okay, results: Ground to center of front wheel well before kit was 35.5" and after was 38.5" after driving it which settles everything in. ReadyLift calls the kit a 2.25" lift, I got 3", going to call them Monday to discuss. Actually the 3" levels the truck exactly, so I am happy with it, just wonder why I got 3" (and yes, I am sure it was installed correctly, pretty hard to screw it up). No change in ride noticed, I did sense the truck riding level, always felt like I was going downhill before.
Here are the before and after pics:
ReadyLift Leveling Kit Install (pics)-before.jpg   ReadyLift Leveling Kit Install (pics)-after.jpg
Old 05-13-2007, 12:45 PM
Dealer : Ira Toyota of Danvers
Last Online: 09-13-2008 10:03 AM
zekeman is on a distinguished road.
zekeman's Photo Albums
Default Re: ReadyLift Leveling Kit Install (pics)
Thanks for posting... my ready lift goes in Tuesday of this week it looks as though your front end is up in the air a little bit?Also do the spacers only go in one way I noticed that the bolt holes and studs are not drilled exactly at each corner of the spacer, two of them look off center?On the Ready Lift web site thay say they are my spacers say they are 2.4 inche spacers.Wondering why you say it is a two person job I was gonna attempt it by myself..
Old 05-13-2007, 01:00 PM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Today 07:00 PM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
Thanks for taking the time to post that. I have the same DC and color and am really looking forward to doing the same kit. If you get a chance could you possibly post a picture of the entire truck before and after? Or maybe just a full pic after?
Thanks again
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 05-13-2007, 01:01 PM
dsmonline's Avatar
2007 Toyota Tundra,
Red face Re: ReadyLift Leveling Kit Install (pics)
They only go on one way, the strut is marked as 'out' and the spacer is marked with a line to match. Web site says they are 2.4", order invoice says it is a 2.25" kit and the actual measurement of the spacer is 1.75". I can understand how a 1.75" spacer makes a 2.25" lift given the change in the spring rate and all, not sure how I got 3". Maybe I should double check the before measurement at the dealer on another truck.
As for the two person suggestion, it's your call, I am just glad I had my brother to help. It probably saved an hour of work and a lot of frustration. There are times when you need to be under the truck and also have the spindle moved out of the way at the same time.
Old 05-13-2007, 01:34 PM
dsmonline's Avatar
2007 Toyota Tundra,
Thanks again
Here are some pics of the entire truck and the spacer on the strut.
Originally Posted by Toxarch View Post
Thanks for sharing that. Did you look at any other leveling kits before you decided on the Ready Lift?
Looked at everything out there, went with the ReadyLift because of it's steel construction and others recommending it. Did not even consider urathane units.
ReadyLift Leveling Kit Install (pics)-strut-w-spacer.jpg   ReadyLift Leveling Kit Install (pics)-before.jpg   ReadyLift Leveling Kit Install (pics)-after.jpg
Old 05-13-2007, 01:53 PM
Jumbo Jet's Avatar
Wow! That looks 100 times better! Now I know exactly how mine will look. Thanks again!
Honda Super Cub
Old 05-13-2007, 02:46 PM
Thanks for the extra info..just so you know I ordered mine direct from ready lift and on my invoice it says nothing about the height of lift...I have the same color truck DC only with TRD.Your truck looks great especially with the ready lift installed, I cant wait...
Old 05-13-2007, 03:50 PM
dsmonline's Avatar
2007 Toyota Tundra,
Mystery Solved!
This was bugging me, so I took a drive down to the local dealership to check it out on some stock trucks. I had misplaced my original measurement I wrote down and had guessed wrong of course, actual wheel well to ground measurement is 36.25" stock (not 35.25") and now that my suspension has settled in nicely, it is 38.5" with the kit. So it does provide a 2.25" lift in the front and it does make the truck appear level when looking at it from the side. I am very happy with the kit, recommend it to anyone wanting just a leveling kit.
Old 05-13-2007, 03:57 PM
Dealer : Reliable Toytota
2007 Toyota Tundra DC 4X4
Last Online: 08-15-2008 06:55 PM
Arkysaw is on a distinguished road.
Arkysaw's Photo Albums
Do you have any vibrations? Will you be adding the differential drop? Any noises from the increased CV angles?
How does it drive now, since the alignment is not at factory spec.?
Thanks for providing this information
Old 05-13-2007, 05:41 PM
TUNDRA RU's Avatar
Dealer : Fairfield Toyota
2002 Toyota Tundra
Last Online: 09-13-2009 06:35 PM
TUNDRA RU is on a distinguished road.
TUNDRA RU's Photo Albums
Also you will loose some lift after you align the truck. I lost about a half inch.
Old 05-13-2007, 06:44 PM
dsmonline's Avatar
2007 Toyota Tundra,
Yes, I agree. I measured the truck just before the alignment and just after, lost just over 1/4". So I lost a total of 3/4" from the time I first dropped the truck off of the jack stands till now.
Old 05-13-2007, 06:46 PM
dsmonline's Avatar
2007 Toyota Tundra,
No vibrations and no additional suspension mods planned. No CV's to worry about, 2WD. Drives just fine, straight and true.
Old 05-14-2007, 06:27 AM
Wondering where you got the torque specs for retightening the bolts?And did you use any loctite?
Old 05-14-2007, 09:21 AM
dsmonline's Avatar
2007 Toyota Tundra,
Did not use loctite as Toyota didn't when they built it. I really don't think it is necessary, however it sure would not hurt anything, so if you usually do use it, go ahead. Use seat-of-the-pants torque values
Old 08-05-2007, 04:49 AM
Dealer : Kauai Toyota
2005 Toyota Tundra
Last Online: 11-18-2008 03:51 PM
Scotty B is on a distinguished road.
Scotty B's Photo Albums
How does a member use the tundrasolutions promo code for this product (#66-5075)?
Tuff Country Leveling Kit? hitman5 1Gen-Tundra 10 11-04-2006 03:15 PM
Anyone Install OME Suspension Kit??? dmalas 1Gen-Sequoia 2 10-24-2006 12:51 AM
K&n Gen Ii Intake Kit nhparrot Engine & Drivetrain 2 07-06-2006 11:19 PM
06' 4x2 Tundra leveling kit jrat 1Gen-Tundra 1 04-16-2006 11:49 PM
03 Single din install kit rx7vert Audio & Stereo 11 03-29-2006 01:44 AM
