Old 05-18-2007, 09:18 AM
Dealer : Cherry Hill Toyota Scion
Last Online: 12-28-2007 09:13 AM
snakehead is on a distinguished road.
snakehead's Photo Albums
Default Problem turning when in 4x4.
I have a 5.7 4x4 Crew Max. When the truck is in 4x4 (4x4 HI -- I really haven't tried LO), I find it very difficult to make turns. The harder the turn I try to make, the more resistance I'm getting. For a tight turn, it feels as if I'm standing on the brakes and the front wheels are binding on something.
I will call this to the attention of the dealer when I bring it in for the first oil change, but wanted to see if anyone on this forum has experienced anything similar.
Please let me know and thanks in advance.
-John
Old 05-18-2007, 09:25 AM
Dealer : Down East Toyota
2007 Toyota Tundra CrewMax SR5, 4x4
Last Online: 03-07-2008 09:19 AM
Northwoods_Maine is on a distinguished road.
Northwoods_Maine's Photo Albums
Default Re: Problem turning when in 4x4.
In this your first 4X4 by chance? Every 4X4 I've owned, regardless of brand has done that if you have 4 wheel engaged on a dry/non slippery surface.
Old 05-18-2007, 09:31 AM
Dealer : Walser Toyota Scion
2007 Toyota Tundra,
1995 Lexus SC300
Last Online: 09-23-2009 08:58 AM
tonyholland00 is on a distinguished road.
tonyholland00's Photo Albums
This is normal.......
Old 05-18-2007, 09:33 AM
2007 Toyota Tundra 5.7L TRD Black
Last Online: 11-23-2009 09:32 AM
blackgts2002 is on a distinguished road.
blackgts2002's Photo Albums
it is very normal . mine does the same thing. when you are in sand, grass, or otherwise soft ground, the turn will be easy. check it out.
Old 05-18-2007, 09:39 AM
GGWOODY's Avatar
Kibble Wrangler
Dealer : Alexander Toyota of Franklin
Last Online: Today 12:04 AM
GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One.
GGWOODY's Photo Albums
Yep, this is a 4x4 standard. Because the rear wheels are not pushing and rolling those front wheels into turns. Give it a touch of gas when turning in 4hi/lo and remember that you likely won't be able to coast into slow/crawling turns. In fact on dry pavement, you will hear the front tires slipping through a turn...there's a lot of torque and the truck will act differently.
use 4hi on wet pavement during takeoffs, standing water in the road, maybe on winding wet pavement, loose dirt, fire roads at high speeds, mud, dune sand, deep gravel or rocks, grass (you don't want to spin the rears and tear up the turf), snow, ice. Any situation where your wheels will spin or you need the added control of power to the front/steering wheels keep it on. Your judgement on when to use it will sharpen as you gain experience with a 4x4.
use 4lo. RARELY. Very low gearing here, and it is best for creeping up or down nasty hills.
have fun!
Want to know what's ironic? My Polish grandparents who were captured during the Warsaw Uprising.
Grandmother was enslaved in a German concentration camp and forced to make artillery shells for the 3rd Reich. Grandfather was in German and Soviet POW camps...ending up in Siberia. After WWII, they moved to the USA to be free, but Obama has turned it into the USSA...Grandaddy is rolling in his grave.
CBTMA Member
Old 05-18-2007, 09:40 AM
Dealer : Street Toyota
2001 Toyota Sequoia 4x4 Ltd,
2007 Toyota Tundra 4x4 TRD DC SR5
Last Online: 09-18-2009 11:24 PM
Shaneshot is on a distinguished road.
Shaneshot's Photo Albums
You are putting alot of pressure on that front end by doing that. This 4x4 system locks the diff so that the front and rear are turning at the same speed. This isn't a system like the Land Rover or Landcruiser that they can operate at different speeds and be friendly for normal driving. This system is made to operate in the slippery stuff. It is better for working, but not simply driving around.
When you make a hard turn, the tires want to go at different speeds, the drivetrain doesn't want to.
Old 05-18-2007, 10:13 AM
EAHinsch's Avatar
Dealer : Fitzgerald's Lakeforest Toyota
2007 Toyota Tundra TRD CrewMax 4X4,
2008 Toyota Camry SE
Last Online: 11-22-2009 02:34 PM
EAHinsch is on a distinguished road.
EAHinsch's Photo Albums
While using 4HI or 4LO the tires need to spin somewhat. You are only supposed to use it when you need it. That's a lot of torque and pressure on the differentials on dry pavement. Be careful or you might shred some steel components. Nothing to worry about though. It is normal.
2007 Tundra CrewMax, SR5, 4x4, 5.7L, TRD MODS: DVD Headrests, Access Lorado Tonneau, BFG All-Terrain T/A's, Brushed Stainless Running Boards, Zoomers Exhaust, TRD Cold Air Intake, and Backup Camera
Old 05-18-2007, 10:34 AM
RMcCleary's Avatar
Dealer : Toyota-Scion Of Bend
2007 Toyota Tundra,
- Other - 1997 Ford F-150
Last Online: Today 12:02 AM
Images: 15
RMcCleary is on a distinguished road.
RMcCleary's Photo Albums
-John
I feel sorry for your tansfer case, I hope you havent driven it on dry surfaces in 4wd that much. The 4wd system in most trucks is not an all time 4wd system like the LandCruiser, Audis or Subarus. It requires some slippage at the front wheels because the rate at which the tires are rotating is different between the front and rear.
2007 Tundra CrewMax SR5, 5.7L, 4x4, Black with Black Interior, Black leather, TRD package, Cold Weather kit, Line-X, Moonroof, BFG All Terrain T/A KOs 285/65/18, SnugTop SnugLid SL, White LED instrument display with Yakima Rack and soon OME Lift, Expedition One Front Bumper, and Expedition One Rear Bumper.
Old 05-18-2007, 10:48 AM
Banned
2008 Toyota Tundra SR5 CM TRD 4x4 5.7,
- Other - Toyota FJ60
Last Online: 07-18-2008 12:35 PM
Sequoia2003 may have some regrets.
Sequoia2003's Photo Albums
OMG, I see you are a noob at 4x4!!!
This is perfectly normal as the front wheels are pulling with the rear wheels pushing all the while you are trying to turn on cement. Do not do this as it's bad for your 4x4 and you just might break something. Popping it in 4x4 HI is fun when it's raining outside and you want to get a jump on someone, but not when it's dry. the only time you should use 4x4 HI is when you you're stuck in two wheel or you require the extra traction like when it's snowing outside. You will probably never require 4 low and the only times you might need that is if you are climbing a really steep slipery hill or descending.
Old 05-18-2007, 11:34 AM
Torch's Avatar
Dealer : Auto Service Company
2007 Toyota Tundra DC SR5 Salsa Red
Last Online: 11-11-2009 12:47 AM
Images: 95
Torch will become famous soon enough.
Torch's Photo Albums
If you haven't figured it out, don't do that on dry pavement. I only use 4x4 when its a slippery mofawker outside. I drive on slicks stuff 7 months of the year.
2007 Tundra TRD 4X4 DC and proud of my 4.7L engine.
Old 05-18-2007, 12:37 PM
Well, I sure do feel pretty stupid, but thank you all for getting back to me. Live and learn.
The only 4x4s I've owned previously are a Honda Pilot (still own it), a VW Passat and Toyota 4Runner. Obviously, this Tundra is the first serious 4x4 I have ever owned. Noob I am. I now have a better understanding of part-time vs. full-time 4wd.
I can't imagine I've done any damage, because I've not had it in 4x4 much (probably less than an hour out of 2,100 miles) and 99% of that was on straight roads. The couple turns I took on dry pavement were at quite slow speeds and I was reluctant to turn hard when I felt the resistance. The Manual does say to drive 10 miles per month in 4wd to keep things lubricated -- otherwise I probably wouldn't have even put it in 4wd.
I feel much better knowing this is normal. I like Shaneshot's explanation that "the wheels want to turn at different speeds but the drivetrain doesn't want to".
Thanks again. I really do appreciate (and obviously needed) the education.
By the way, I love the truck.
Old 05-18-2007, 12:58 PM
GGWOODY's Avatar
Kibble Wrangler
Don't feel stupid man! You just didn't know...I think most folks on here posted without reading what others had written, so there was a lot of redundancy, but from good folks who wanted to make sure that you knew how best to treat your rig.
Yes, to Shaneshot's point...4x4 is much different than AWD. You didn't hurt anything probably, since you're supposed to keep the transfer case lubed once a month, your small amount of drive time didn't hurt a thing.
You are good to go...Enjoy your ride!!
CBTMA Member
Old 05-18-2007, 01:38 PM
Dealer : Big Two Toyota & Scion of Chandler
Last Online: 03-08-2008 07:56 PM
PeptoBismol is on a distinguished road.
PeptoBismol's Photo Albums
Just remember to continue to put the vehicle into 4x4 (hi) at least once a month, and go for a drive. This keeps all the internals properly lubricated. When and if you need to get into a parking lot, or tight turn, simply revert back to 2x4.
Good Luck!!
Pepto
Got Pepto???
07 Tundra, CrewMax, 4x2. 5.7L SR5, Slate Metallic, Nav, MoonRoof, TRD Dual Exhaust, CS, VIP remote engine start, Alloy Wheels 18's, Bluetooth, also with HM, MG, CK, BU, RL, CF, N1, DS, and a bed extender for free WOOT!
Old 05-18-2007, 03:11 PM
Dealer : Camelback Toyota Scion
2007 Toyota Tundra 4x4 Crewmax Limited
Last Online: 09-23-2009 12:11 PM
Images: 10
hbonney is on a distinguished road.
hbonney's Photo Albums
The problem in 4 wheel drive is that the front and rear wheels travel in a different arc...try driving through a water puddle (in 2 wheel drive) to get the tires wet, then drive onto dry pavement and turn sharply. Look at the tracks you made, and you will see that the front and rear wheels don't follow the same path. The same goes for inside and outside wheels....the outside wheels in a turn have to travel a greater distance than the inside wheels...hence the differential to compensate for that. You will get binding in the drivetrain if you use 4x4 on dry pavement with a direct drive transfer case like the ones in Tundras....if you think its hard to turn with a Tundra in 4 wheel drive, try a fully locked up rig(front and rear lockers) and take a sharp turn with it....I've modified the shifter on my Land Cruiser so I can shift into 2 wheel drive Low and make a sharp turn off road and once I'm pointed in the direction I wanted, I shift back to 4-Lo.
2007 Crewmax Limited 4x4 Nautical Blue, OME 2.5 inch front lift, OME Dakar 2.5 inch rear leaves, BFG 305x55x20 Mud Terrain KM2's on stock 20 inch rims
Old 05-18-2007, 03:57 PM
Banned
Yeah, don't feel stupid cause you just did not know.
Have some fun with it during the rain. Pull up next to some kid in a Honda Accord all tricked out and slip the Tundra in 4HI and launch into the next county while he's spinning his front tires.
06 Tacoma clutch problem stevegittings Tacoma 103 10-24-2009 10:15 AM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
Kenwood DDX7015 Screen tilt problem Longboarder Audio & Stereo 16 05-28-2008 05:06 PM
4x4 Pass Baggers shane4x4 Southwest 0 04-17-2007 06:23 PM
Help? To 4x4 or not to 4x4 jsftex Tundra 17 04-17-2007 08:27 AM
