From our site FAQ - Use of photos in posts
When embedding photos into a post, please do not make them bigger than 800x600 pixels. Make them a clickable link instead, so it will open the photo up in a new browser window. It is not fun to have to scroll back and forth in posts where huge photos are embedded. Embedded photos larger than 800x600 pixels will either be converted to links or removed.
Reason: Embedded photos larger than 800x600 pixels converted to links
__________________ '05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Beutiful truck, definitely one of the best three I've seen. What type of wheels are those, very nice. Trying to decide myself between to slate grey, pyrite mica and blue nautical with same lift, also crew max vs. double cab.
Sweet thanks for that, I could not figure it out! Not the sharpest crayon in the box when it comes to computers.
This wouldn't fit in the IM correctly so I'll drop it here,maybe someone else can benefit from it as well ? Its pretty simple actually, You see the "img code" where you uploaded your pics in PhotoBucket? {example} URL Link HTML Tag **IMG Code **
If you left click the box to the right of the "IMG Code"it will auto copy the hyper link that can then be pasted directly into your forum "message body"
A real easy way to post several pics at once,
Open Outlook Exp. Create New,then close OE main window,then expand the create window and use it like a clipboard to paste all your IMG links to. They should look something like this;
*[IMG]http://i120.photobucket.com/albums *[/IMG] > **You must have 2[IMG] for every link copied
You get this far you then go to the,Top Tool Bar Select "Edit" then click "Select All"
Everything should be highlighted at this point.
Now put your pointer over one of the highlighted links and right click,then select "Copy"
Now your ready to paste the info into the message body on the forum.
Open forum message body then left click to set the cursor in the window.Now Right click then select "paste".
Everything you copied should now be inside the message body ?
You can now add text at the top or bottom or in between picture links.
NOW !!! You can click on "Preview Post",then select "Post"if you like what you see.If you hit "Back" you'll have to start all over again.
Did you notice the ** above ?
When you split links to add text in between pictures make sure each link has 2 of the [IMG] or your pic will not post.
How tall is it now? I'm wondering which parking garages will be accessible with that setup. Most buildings here have a height restriction of around 6'6".
I aswell would like to know about any rubbing.
Do you just have a front level kit?I was told 33 are a tight fit with a 3 inch front kit.
Alot off guy around at the shops cant tell me a straight answer(here in Canada) yet.
