Does this hurt the transmission?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Does this hurt the transmission?
  1. #1
    Supporter asianflava's Avatar
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    Default Does this hurt the transmission?
    Does it hurt the transmission to shift into neutral to coast down, then shifting it back into gear. This is the first automatic I've owned, I'd coast down with my manual cars all the time. If I just lift off the gas, the trans will drag me down so that I will slow down faster than I want.
    I tried it on the way to and from work (22mi one way) and managed to get the mileage computer up to 19MPG.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    VPI
    VPI is offline
    Junior Member VPI's Avatar
    Join Date
    Jan 2007
    Location
    Tennessee
    Posts
    146
    Liked
    0 times
    Rep Power
    9
    Default Re: Does this hurt the transmission?
    Should not hurt the transmission. You could also flip it in to manual mode and up shift. If your foot is not on the throttle you are not using that much fuel.
    07 DoubleCab SR5 4x4 5.7 TRD.
  4. #3
    Fellow Tundra Owner RitcheyRch's Avatar
    Join Date
    Aug 2002
    Location
    Santa Clarita
    Posts
    1,837
    Liked
    36 times
    Images
    2
    Rep Power
    2679
    It is bad for the transmission. When you put it in neutrail it stops pumping much needed oil to the vital parts of the transmission.
  5. #4
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    Just be careful and don't go into R....that might make a lot of noise. Personally I don't think it's a good idea to coast down hills, but to each his own.......
    '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
  6. #5
    Junior Member pintnight's Avatar
    Join Date
    May 2005
    Location
    West of Dallas, East of Ft. Worth
    Age
    48
    Posts
    158
    Liked
    0 times
    Rep Power
    11
    Automatic transmissions does not work the same way as manual transmissions. Automatic transmissions use pressure plates using oils to help change gears. By constantly putting the automatic transmissions into neutral your just making your transmissions work harder.
    I would advise that you not do that while driving around.
  7. #6
    Join Date
    Aug 2002
    Location
    Santa Clarita
    Posts
    1,837
    Liked
    36 times
    Images
    2
    Rep Power
    2679
    Actually against the law in CA to coast down hills. Vehicle needs to be under power at all times.
    Quote Originally Posted by LeeinAZ View Post
  8. #7
    Veteran Member Wacked's Avatar
    Join Date
    Apr 2007
    Location
    Richmond, TX
    Age
    49
    Posts
    1,658
    Liked
    67 times
    Images
    23
    Rep Power
    133629
    Not as long as the motor is running it won't necessaraly (sp) huurt anything in the short term, the pump is driven by the torque converter that is connected to the flywheel, connected to the crankshaft. It could eventually effect the torque converter and also the drums/pistons/clutch packs for the gear it is being put back into coming out of neutral
  9. #8
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    Thanks for the info....but I try to stay away from that State as much as possible. Too many people and too many weird laws...plus I can't carry my S&W there either.
  10. #9
    Junior Member Mister's Avatar
    Join Date
    Apr 2007
    Location
    Conroe, Texas
    Posts
    260
    Liked
    0 times
    Rep Power
    9
    Shifted into R today at 45MPH. Didnt do a thing, when i came to a dead stop it shifted into reverse and not a single noise was made. Looks like this truck is idiot proof
  11. #10
    Slowpoke shooter2jim's Avatar
    Join Date
    Jul 2002
    Location
    Chattanooga, TN
    Posts
    608
    Liked
    1 times
    Rep Power
    20
    Quote Originally Posted by Mister View Post
    On purpose?
    Just kidding
  12. #11
    Join Date
    Sep 2005
    Location
    Upland, CA
    Posts
    583
    Liked
    1 times
    Rep Power
    76
    It's possible that the electronics controlling the trans will not let you shift into reverse at that speed, but I don't know.
  13. #12
    Supercharged Member Only Toyota for me's Avatar
    Join Date
    Nov 2006
    Location
    Pleasant Grove, UT
    Posts
    2,228
    Liked
    0 times
    Images
    50
    Rep Power
    1266
    Smart on toyota's part there!!
    My grandpa was towing his 5th wheel with his chebby and did that on the freeway with the cruise set. That was a costly mistake. New tranny.:cry:
  14. #13
    Jedi Ninja in Training mxsjw's Avatar
    Join Date
    Jan 2007
    Location
    Lakewood, WA
    Posts
    8,309
    Liked
    13 times
    Images
    12
    Rep Power
    79
    Just an FYI to take it for what it is worth.
    The manual says specifically, in a yellow box, in bold print, not to ever do that.
    Beer please!
  15. #14
    Veteran Member willy's Avatar
    Join Date
    Aug 2002
    Location
    Nevada
    Posts
    1,672
    Liked
    3 times
    Rep Power
    15
    Quote Originally Posted by pintnight View Post
    Take this man's good advice. If you want your tranny to last, drive the automatic like it was designed to be driven.
    Besides, so you got 1 mpg better. After 100,000 miles, at 18 vs 19 MPG, that'll save you 292 gallons. Is it really worth the hassle to save that much gas over the course of 100,000 miles. Not at all.
  16. #15
    Veteran Member 93cruiser's Avatar
    Join Date
    Aug 2004
    Location
    nj
    Posts
    535
    Liked
    5 times
    Images
    1
    Rep Power
    12
    dangerous, always should have the truck under power. your not saving any gas anyway, i get 99.9 mpg going down hill under no load at speed, according to the readout. your doing needless shifting and just putting more strain on your nice expensive transmission. stop now.
    2007 Tundra CrewMax SR5 4x4
    2013 Toyota Rav4 XLE
    1972 Land Cruiser FJ40
    2007 Nissan Altima 3.5SL
    2002 YZ250F
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. transmission flush
    By nhparrot in forum Transmission
    Last Post: 07-10-2014, 05:13 PM
  2. Extending Automatic Transmission Life
    By Transdude in forum Transmission
    Last Post: 03-28-2014, 01:39 AM
  3. Shift L???
    By bunker7 in forum 1Gen-Tundra
    Last Post: 05-02-2007, 01:27 PM
  4. Replacement Transmission for 2000 Tundra with 38k
    By johnmgeorge in forum Transmission
    Last Post: 07-08-2004, 04:27 PM
  5. Auto transmission questions
    By Laubypt in forum Transmission
    Last Post: 08-23-2003, 07:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
