OBD II Scanner - Transmission Fluid Temp - Toyota Tundra Forums : Tundra Solutions Forum
 2Likes
  • 1 Post By ObChristo
LinkBack Thread Tools
post #1 of 11 (permalink) Old 04-17-2019, 08:03 AM Thread Starter
Has anybody found a scanner that will read our transmission fluid temperatures properly? Ive done a good bit of searching and it doesnt seem as though anybody has cracked the code on the 5 spd trans. Ideally, I would like to get a Bluetooth scanner that I could move between vehicles but mostly Im interested in reading TFT for my 05 Tundra DC and 08 Sequoia (5.7).
Sent from my iPhone using Tapatalk
Don Tibbetts is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 04-19-2019, 07:06 AM
2003bajatundra4x4ac's Avatar
Re: OBD II Scanner - Transmission Fluid Temp
search is your friend! all of your answers are here in the google search box -------------------------------------------------------------->
first one's free: https://www.tundrasolutions.com/foru...r-tranny-temp/
All you Baja lovers check out:
2003bajatundra4x4ac is offline
post #3 of 11 (permalink) Old 04-21-2019, 01:50 PM
SuckersWalk's Avatar
Back in the day, I got the ATF temp to show on my Torque App reading a OBDII BT plug I got off Amazon. Now, these are dirt cheap.
Search for your answer.
SuckersWalk is offline
post #4 of 11 (permalink) Old 04-23-2019, 04:21 PM
Scangauge II, the best IMO. https://www.scangauge.com/ all you do is input the proper code for your truck and it will read the temp just fine. Best choice though just follow the link 2003bajatundra4x4ac suggested. Forgot to mention, make sure the unit you buy from scangauge has the latest firmware, buyt it directly from them and you won't have an issue at all, then input the code that's posted in their website and you are good to go.
bantley19 is offline
post #5 of 11 (permalink) Old 04-23-2019, 06:24 PM Thread Starter
Thanks everyone for replying. I actually have a ScanGuage. Ive tried all the codes I could find online. I even tried modifying some of the ones that have been reported to work on other Yotas. I will try the codes posted above and report back on whether they work or not.
post #6 of 11 (permalink) Old 04-23-2019, 06:26 PM Thread Starter
One of our boys has a Samsung. All the rest of the clan are Apple fanbois. I may see if I can get him to put Torque on his phone and see if I can get it to work.
post #7 of 11 (permalink) Old 04-23-2019, 06:59 PM
I use a cheap Bluetooth OBD II Dongle and the Torque Pro App on any of my android devices (I have a phone and a double DIN Atoto A6 Android headunit as a stereo) with the following custom PID to get both Pan and Converter Temp. Works great! Not sure why anyone would spend the dough on a scanguage when you can use this setup.
For sensor 1 (Pan Temp):
OBD2 Mode and PID:
21D9
Long Name:
Transmission Fluid Temperature 1
Short Name:
TFT 1
Minimum Value:
0.0
Maximum value:
220.0
Scale factor:
x1
Unit Type:
F (there is a degree symbol in Torque)
Equation:
((((E*256)+F) * (7/100) – 400)/10)
OBD Header to use:
left blank
For sensor 2 (Converter outlet temp):
OBD2 Mode and PID:
21D9
Long Name:
Transmission Fluid Temperature 2
Short Name:
TFT 2
Minimum Value:
0.0
Maximum value:
220.0
Scale factor:
x1
Unit Type:
Equation:
((((G*256)+H) * (7/100) – 400)/10)
OBD Header to use:
left blank
ObChristo is offline
post #8 of 11 (permalink) Old 04-23-2019, 07:03 PM Thread Starter
OBD2 Mode and PID:
21D9
Long Name:
Short Name:
TFT 1
Minimum Value:
0.0
Maximum value:
220.0
Scale factor:
x1
Unit Type:
Equation:
((((E*256)+F) * (7/100) 400)/10)
OBD Header to use:
left blank
OBD2 Mode and PID:
21D9
Long Name:
Short Name:
TFT 2
Minimum Value:
0.0
Maximum value:
220.0
Scale factor:
x1
Unit Type:
Equation:
((((G*256)+H) * (7/100) 400)/10)
OBD Header to use:
left blank
This is exactly what I was looking for. Thank you!
I wish there was something that worked with Apple but I will happily buy a dedicated device to use with the Trucks if I can make this work.
What year is your truck? And do you know what Bluetooth dongle youre using?
post #9 of 11 (permalink) Old 04-23-2019, 07:13 PM
I have a 2005 Sequoia SR5 4WD with the 4.7.
I have 2 Dongles and they both work with Torque Pro
Don Tibbetts likes this.
post #10 of 11 (permalink) Old 04-23-2019, 07:13 PM
Dongle 1: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Dongle 2: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #11 of 11 (permalink) Old 04-24-2019, 06:54 AM Thread Starter
Thank you so much. I will check them out.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
