weird "thud" when accelerating - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 8 (permalink) Old 05-11-2019, 12:14 PM Thread Starter
hello all!
so i am going on 2 years with my beloved 2005 Double cab tundra with 187k miles. love the truck! since i got it I've been trying to fix little issues it had and have come an issue that I've noticed in the last few months. other than suspension (Bilstein 5100 w/ camburg UCAs) i have not messed with any of the drive train or engine other than oil changes (engine only) so my issue is when I'm driving down the road and decided to pass a slower moving vehicle i step on the gas and almost as soon as the engine revs up i feel a thud which seems to come from my under my seat and or transmission area. i have also noticed that when my truck is cold usually in the mornings before work i drive off and when i come to a stop sign the rpms drop and feel that thud. almost as if my truck did not downshift until i come to the stop. like i stated i have never flushed the transmission since i acquired the truck and wonder if that would be something to look into? I hear people say you shouldn't flush your automatic transmissions because once you do they end up shifting hard and or failing. Not sure if that's just a myth but would like to know what you all think. Thank you in advance!
efrencruzer93 is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 05-11-2019, 02:07 PM
Tundruz's Avatar
Re: weird "thud" when accelerating
Grease your driveshafts zerk fittings.
Tundruz is offline
post #3 of 8 (permalink) Old 05-12-2019, 05:44 PM
Yes Iím unsure about the thud when you hit the throttle, but the thud when you stop and the rpms drop sounds just like the driveshaft slipjoint. Mine will do it lightly still When the A/C is on only. When the compressor turns off and the truck drops rpm at a stoplight Iíll get a minor thud. Before I greased the slip joint it would feel like I got rear ended every time it happened. Been a few years, I need to grease it again. I would grease it and see if both problems go away
Sent from my iPhone using Tapatalk
01tundraDC is offline
post #4 of 8 (permalink) Old 05-14-2019, 03:56 PM
I understand there are NO grease fittings so that doesn't help.
I had a weird clunk under my '05 and it turned out to be a loose tranny mounting bolt. Was very pleased to find an honest mechanic in a new town and was only charged 1/2 hour labor. Don't know how they found it so fast by I suspect it wasn't a new problem to them....?
flyingriki is offline
post #5 of 8 (permalink) Old 05-14-2019, 04:20 PM
Center support bearing would be my guess. If it's never been replaced, it's definitely due at that mileage.
Schly is offline
post #6 of 8 (permalink) Old 05-14-2019, 05:44 PM
Tundruz's Avatar
Not sure if you're joking or haven't bothered to look but both my 2000AC and 2005DC Tundras have zerk fittings on the driveshafts. Maybe yours doesn't or you don't know what/where to look at.
Glad you solved your loose tranny though.
Tundruz is offline
post #7 of 8 (permalink) Old 05-15-2019, 05:06 AM
If you donít have one then I donít know. It doesnít make sense to not have one though, itís a sliding metal to metal section. I was under the impression that every first gen had a grease zerk for the slip joint. Factory U-joints donít have them, but the slip joint should. If you wanna pursue any transmission work, I would research on this forum heavily first. I donít flush mine I just drain the pan and top it back off, but you have a different transmission than my 01 does, so I can be of no assistance in that regard.
post #8 of 8 (permalink) Old 05-15-2019, 08:18 AM
I saw somewhere in the forums that 4WD Tundras have a zerk fitting but 2WD Tundras don't. I cannot verify if this is true.
grumps is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
