2007 tundra brake pads sticking - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 7 (permalink) Old 09-03-2016, 07:50 AM Thread Starter
Just replaced rotters and pads with Duralast Gold Brake Rotor and pads. After putting everything back on and bleeding the system. I hear a sound when I go to release my foot off the brake peddle as if they pads are not releasing from the rotters. It's coming from both sides. Now the new pads area little bit thicker, but that should be an issue.
any advise?
pacman75 is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 09-03-2016, 08:09 AM
mendonsy's Avatar
Re: 2007 tundra brake pads sticking
Did you replace the pins that hold the pads in place?? They can cause the pads to hang up.
'19 SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
Toyota bed step
Weathertech Vent Visors
Ultragauge EM
Techstream
CBTMA member
mendonsy is online now
post #3 of 7 (permalink) Old 09-03-2016, 08:26 AM Thread Starter
No I did not replace the pins, they looked good. But should they be replaced?
pacman75 is offline
post #4 of 7 (permalink) Old 09-03-2016, 09:50 AM
mendonsy's Avatar
They only need to be replaced if they have wear marks in them or have corrosion. Around here that means I have to change them every time I change pads because the road salt gets to them.
Toyota SS steps
ARE MX cap
Toyota bed step
Ultragauge EM
Techstream
CBTMA member
post #5 of 7 (permalink) Old 09-03-2016, 10:12 AM Thread Starter
The pins were a little sticky going in an out, so I'll pick up some new ones today and replace them to see if that is an issue.
pacman75 is offline
post #6 of 7 (permalink) Old 09-03-2016, 12:55 PM
mendonsy's Avatar
A very small amount of never-seize compound in the holes through the pads and calipers won't hurt either. Don't get carried away though, just a small amount!
Toyota SS steps
ARE MX cap
Toyota bed step
Ultragauge EM
Techstream
CBTMA member
post #7 of 7 (permalink) Old 02-01-2018, 10:50 AM
I have a similar issue. not sure how severe of an issue this will cause other than premature pad wear
Ron Hel
RonHel64 is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
