Toyota Brake Specifications - Toyota Tundra Forums : Tundra Solutions Forum
 1Likes
  • 1 Post By topdown4runner
LinkBack Thread Tools
post #1 of 12 (permalink) Old 01-30-2008, 04:09 AM Thread Starter
MEvang's Avatar
I'm starting this thread as a quick reference spot for Toyota Brake specifications. I'll start off with the Tundra and add a few now and then.
If you have a request for a certain model please chime in and I'll get it for you.
Also if you have any question about a specification please ask.
Most of these will come from Motors Information Systems 1977-2007 Disc & Drum Brake Specification and Bleeding Sequence Guide.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
MEvang is offline
Sponsored Links
Advertisement
post #2 of 12 (permalink) Old 01-30-2008, 04:14 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications Tundra 00-06
Tundra: 2000- 2006
Front Brakes
Calipers: Four Piston Fixed
Caliper to Upright Torque: 90 lbft
Maximum Parallel
Variation: Not Specified by Manufacture
Runout Limit: .0028"
Normal Thickness: 1.102"
Minimum Machining: Not Specified by Manufacture
Discard at or Under: 1.024"
Finish Microinch: Not Specified by Manufacture
Rear Brakes
Type : Drum
Runout Limit: Not Specified by Manufacture
Nominal Diameter: 11.614"
Maximum Machining: 11.693"
Wheel Nut Torque: 83 lbft
Brake Bleeding Sequence: None Specified
MEvang is offline
post #3 of 12 (permalink) Old 01-31-2008, 04:37 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications: Sequia 01-07
Sequoia 2001- 2007
Front Brakes
Maximum Parallel
Rear Brakes
Type: Disc
Calipers: Single Piston Sliding Pins
Caliper Mounting Torque: 65 lbft
Maximum Parallel
Runout Limit: .0039"
Normal Thickness: .709"
Discard at or Under: .611"
Park Brake
Type: Drum
Nominal Diameter: 8.270"
Discard At Or Over: 8.310"
MEvang is offline
post #4 of 12 (permalink) Old 02-01-2008, 04:15 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications: Tacoma Prerunner '07
Tacoma: 2WD 4WD and Prerunner 2007
Front Brakes
Calipers: Not Given
Caliper to Upright Torque: Caliper Bolts 2WD except Prerunner, 27lbft – 2WD Prerunner, 4WD Caliper Bolts 90 lbft; 2WD ex. Prerunner caliper bolts 80 lbft
Maximum Parallel
Runout Limit: .0020"
Normal Thickness: 2WD .984”
4WD & Prerunner 1.102”
Discard at or Under: 2WD .906”
4WD & Prerunner 1.024”
Rear Brakes
Type: Drum
Nominal Diameter: 10.00"
Maximum Machining: Not Specified by Manufacture
Discard at or Over: 10.079”
Special Bleeding Procedures:
1. Bleed the wheel brakes, no sequence given.
2. After bleeding air from the brakes system, if the height or feel of the brake pedal cannot be obtained, bleed air from actuator assembly using Hand-held tester by following steps below.
A. Depress the brake pedal more then 20 times with engine off.
B. Connect Hand-held tester to the DLC3
C. Turn ignition switch to the ON position
D. Select "Air Bleeding"
E. Bleed the air by following the steps displayed on the Hand- held tester
MEvang is offline
post #5 of 12 (permalink) Old 02-01-2008, 04:22 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications: Tacoma, Prerunner '06
Tacoma: 2WD 4WD and Prerunner 2006
Front Brakes
Calipers: 2WD except Prerunner: Single Piston Sliding Pins
4WD and Prerunner 4 Piston Fixed
Maximum Parallel
Normal Thickness: 2WD .987”
Rear Brakes
Type: Drum
Maximum Machining: 10.079”
Wheel Nut Torque: 85 lbft
MEvang is offline
post #6 of 12 (permalink) Old 02-18-2008, 04:31 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications: Highlander 2001-2006
Highlander: 2001-2006
Front Brakes
Calipers: Single Piston Sliding PIns
Caliper Torque: Caliper Pin Bolts 25 ftlb
Bracket to Upright Bolts 79 lbft
Maximum Parallel
Normal Thickness: 1.102”
Discard at or Under: 1.024”
Rear Brakes
Type: Disc
Caliper Torque: Caliper Pin Bolts 25 lbft (32 lbft 05-06)
Bracket to Upright Bolts 44 lbft (58 lbft 05-06)
Maximum Parallel
Runout Limit: .0059"
Normal Thickness: .433”
Discard at or Under: .390”
Park Brake
Type: Drum
Nominal Diameter: 6.690"
Discard At Or Over: 6.730"
Wheel Nut Torque: 76 lbft
MEvang is offline
post #7 of 12 (permalink) Old 02-19-2008, 04:04 AM Thread Starter
MEvang's Avatar
Re: Toyota Brake Specifications: Highlander 2007-
Highlander: 2007-
Front Brakes
Caliper to Upright Torque: Caliper Pin Bolts 25 ftlb
Maximum Parallel
Rear Brakes
Type: Disc
Caliper to Upright Torque: Caliper Pin Bolts 32 lbft
Bracket to Upright Bolts 58 lbft
Maximum Parallel
Normal Thickness: .394”
Discard at or Under: .355”
Park Brake
Type: Drum
Nominal Diameter: 7.48"
Discard At Or Over: 7.52"
MEvang is offline
post #8 of 12 (permalink) Old 12-18-2009, 05:31 PM
Do you have this same info for a 2007 Tundra?
jeffmort is offline
post #9 of 12 (permalink) Old 09-15-2010, 03:07 PM
bump? 2007 tundra...?
razorbackpro is offline
post #10 of 12 (permalink) Old 04-06-2011, 05:21 AM
Even i got this information due to this post thanks for that.
Peter Martin is offline
post #11 of 12 (permalink) Old 01-13-2015, 10:52 AM
1st2008Tundra's Avatar
Garage
What about the Tundra from 2007 to present?
1st2008Tundra is offline
post #12 of 12 (permalink) Old 02-19-2016, 02:14 PM
Seriously...
Truck is in the air, removed the rear caliper brackets to beat back the backing plate that the disk rubs on.
Can't find the damn torque to put it back together!
triharder likes this.
topdown4runner is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
