Disable DRL - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 15 (permalink) Old 11-22-2005, 03:35 PM Thread Starter
Disable DRL
anybody know how to diable the day time running lights on the 2006 corolla? Im getting hid's and wanted to disable them. I asked toyota and they said its illegal so they wont do it for me. I looked on a corolla forum and they have a post on how to do it, but im not sure if its the right way to do it.
supritdeol is offline
Sponsored Links
Advertisement
post #2 of 15 (permalink) Old 11-22-2005, 07:10 PM Thread Starter
http://9thgencorolla.com/forums/viewtopic.php?t=4922
thats what i found on the corolla forum, but i dont know if that will work. The dealership told me that it could possibly screw up something by the method describe in the link.
Any info would be helpful because i need to disable my drl's so i can run HID's
post #3 of 15 (permalink) Old 04-04-2007, 07:07 PM
Re: Disable DRL
I have been trying to find a way to disable my 2006 Corolla DRLs since I bought the car. Nothing illegal about disabling because there is no federal mandate for DRLs. Only procedure I have seen is a Toyota TSB that deals with the 8th generation Corollas (1997(?) to 2002). I now have my dealer's Customer Relations mgr checking with Toyota to get an answer. I will find a way to get them disabled and will post results.
ddalpz is offline
post #4 of 15 (permalink) Old 04-16-2007, 01:29 PM
Txstick is offline
post #5 of 15 (permalink) Old 06-06-2007, 01:09 PM
Re: Disable DRL
Thanks for posting this year 2000 model pdf.
But what we need is a diagram for a 2006 model.
Do you have access to one of those?
9phil9 is offline
post #6 of 15 (permalink) Old 06-08-2007, 11:15 PM
tundra2501's Avatar
Send a message via AIM to tundra2501
Re: Disable DRL
* * * * * Fixed Strobing Of Hids w/Harness MOD!! <--- Come In Here To Fix Yours - 9thgencorolla.com
There is a harness now so you are able to run HID
2001 Toyota Tundra: RCD 6inch lift, Total Chaos steering bushings, Clear Corners, Rhino lining, Mickey Thompson rims w/ 35inch Dean SXT's, Flowmaster, Boston Pros front and rear, Q-Logic sub box with 2 JLW3v2's, JL Stealth Box.
tundra2501 is offline
post #7 of 15 (permalink) Old 06-13-2007, 11:35 AM
Re: Disable DRL
Just to make sure you got an answer to your original question, I too installed HID's and all I did was cut the red wire at #12 as shown in the picture.
That's ALL. One snip and the job's done.
All that rewiring jimmy jammy is a waste of time.
Just don't cut it too close to the module so that it can be easily repaired if you ever want to have auto headlights again.
9phil9 is offline
post #8 of 15 (permalink) Old 03-30-2010, 03:04 PM
Re: Disable DRL
so which one do i cut the yellow or the red one and do i have to ground it to anything let me knoe ok thanks email me at [email protected]
05corollas is offline
post #9 of 15 (permalink) Old 03-30-2010, 09:11 PM
Re: Disable DRL
Did you look at the picture that was posted with my reply? If not, then click on it and look at it closely.
9phil9 is offline
post #10 of 15 (permalink) Old 07-25-2010, 08:52 AM
05' Tundra (Tun-Tun)
netrickyaz's Avatar
Send a message via AIM to netrickyaz
Re: Disable DRL
HEY thanks for the tip...i didn't wanna be down there moving a bunch of wires around i wanted a quick solution this works
[SIGPIC][/SIGPIC]
2005 Toyota Tundra Blue Steel Metallic (SR5 Access 4.7L i-Force V8 with VVT-i)
( De-Badged, K&N 77 Series Intake With Painted Tube (Wrinkle Black)17" Limited Rims with Good Year Wranglers (265-70-17s), V-LEDS 5000k Hi/Lo Headlights, V-LEDS 5000k Fogs (as DRL), Blacked Out Headlights, Tinted Side Markers, Black LED Tail Lights, Black Side Molding, Black Billet Grille, Kenwood Deck, Infinity Speakers, Alpine 5-Channel Amp (Doors), 12" Infinity Sub(Custom Box), Infinity Mono Amp (Sub)
(Future: 3" Lift Kit, Magnaflow 22" Single-Dual Exhaust)
CarDomain:
netrickyaz is offline
post #11 of 15 (permalink) Old 09-12-2011, 12:59 PM
Re: Disable DRL
9phil9 you said, "to cut the red wire at #12 as shown in the pic" Where is this located in the 2006 Corolla?
spatel21 is offline
post #12 of 15 (permalink) Old 09-12-2011, 09:53 PM
Re: Disable DRL
I don't understand your question. Are you asking where this module is located? Or are you asking which wire the picture shows.
9phil9 is offline
post #13 of 15 (permalink) Old 09-13-2011, 06:09 AM
Re: Disable DRL
Yes, where is that module located in your pic you posted? Also would you know where the DRL relay is located?
spatel21 is offline
post #14 of 15 (permalink) Old 09-13-2011, 08:32 AM
Re: Disable DRL
Yes, where is that module located in your pic you posted? Also would you know where the DRL relay is located? Also that wire you are cutting is there anything else being controlled or is it just the DRL?
spatel21 is offline
post #15 of 15 (permalink) Old 09-13-2011, 09:35 PM
Re: Disable DRL
It's connected to the right side of the steering column, about mid way between the firewall and the dash. If you lay your drivers seat back all the way down, you can lay on your back and look up behind the dash. (Now there's a clever tip you're not going to read anywhere else.)
From that position, the relay/connector that is pictured, will be to your left. (Right side of the column.)
Cutting the red wire as marked in the picture will disable, the DRL's and also the "Auto" headlights feature.
But I prefer to turn my own headlights on and off, thank you Government Bureaucrats, and Insurance Nazi's....NOT.
So if you decide to cut the wire, in order to use HID's..then be sure to cut it about two inches, or so, from the plug, so it will be easy to reverse in the future, should you ever decide to go back to dim Halogen bulbs and Automatic Headlights.
A word of caution here too.
And this is important.
DO NOT DRIVE YOUR CAR OUT ON THE ROAD UNTIL YOU RE-AIM YOUR LIGHTS !!!
(Yeah I'm yelling that, and for good reason.)
The HID's light source, and the halogen filament are not exactly at the same point, so the light could be aimed too high.
You could blind oncoming traffic with the new HID's....and you never know how pissed off somebody can get until you blind them.
Just keep in mind they might be armed, and just pissed enough to follow you...and then put an end to your lights. (I guess that would mean, like punching your lights out, huh?) lol
Enjoy your car, and respect others at the same time.
Good policy to live by.
9phil9 is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
