Front End Leveling and Fuel Economy - Toyota Tundra Forums : Tundra Solutions Forum
 1Likes
  • 1 Post By bryank
LinkBack Thread Tools
post #1 of 11 (permalink) Old 05-06-2012, 06:46 PM Thread Starter
joelorensen's Avatar
I've been thinking pretty hard about adding some Bilstein 5100s to my 05' DC......wanna bring it up just a little. However, I'm wondering if I would see a drop in fuel economy by doing so??? What I invision is running the 5100s on the second notch (about 1.25" of lift)....wanna make sure the final product doesn't look like the truck has something heavy in the bed. Seems like it wouldn't be an issue, but not sure how the aerodynamics might be changed.
Joe
Phantom Gray 05' DC 4x4.....BAMuffler!!!
joelorensen is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 05-06-2012, 07:10 PM
Das Jugghead
Highwaylizard's Avatar
Re: Front End Leveling and Fuel Economy
Good question. Theoretically raising the front increases the profile of the truck and would have a negative impact on fuel economy. That being said, how much of an effect, is up for grabs. If I had to guess I would venture a half a MPG on the highway - less of a an impact with in town driving. I would be really interested in your results and hope you will post up your findings.
355,164 miles on the odometer [come see me when you get that on your ford]
2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, Ultragauge, Long Tubes with x-pipe and true duals,stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA [COLOR=Black]in the differentials. 3:91 gears in the front and rear [SIZE=2]differentials, Cooper Discover ATP tires
Highwaylizard is offline
post #3 of 11 (permalink) Old 06-04-2012, 01:33 AM
My friend installed a Toytec 3" leveling kit on the front only on his '09 double-cab...different engine than you, but his mileage decreased by about 2 mpg local, and 1 mpg on the highway. Hope that sheds an idea.
Ballbearing is offline
post #4 of 11 (permalink) Old 06-04-2012, 07:46 AM
toyotalover79's Avatar
I would listen to Highway. His words are gold when it comes to research and experience. Just my 2cents.
toyotalover79 is offline
post #5 of 11 (permalink) Old 06-15-2014, 09:59 PM
I raised the front about 1.5" on my 06 4x4 DC and made the change to a 265/75/16 AT tire from a 265/70/16 HT and over 7 months I haven't noticed much of a change. I recently did a 600 mile trip and got 17.5 mpg - pretty much equal to the best I got before the switch.
Overall I wish I could find a way to squeeze some better MPGs out, but considering the negligible change I've noted, the leveled (or near leveled) look/stance and more capable AT tires are def worth it.
jackflash is offline
post #6 of 11 (permalink) Old 08-01-2014, 02:57 PM
corc305's Avatar
I also did the Bilstein 5100s at the 2nd notch in the front. I was concerned about the bed level as well. In fact I asked the shop to level it, they placed it at the 3rd notch and it was notably not level. They offered to take it to the 2nd, which required an alignment, and it is perfect.
Also I did feel like the gas mileage is a little worse, but I don't keep a solid number and I always fight an urge to get on the pedal. In the end I'm happy, I feel a little more confident driving through some trails and I like the stance of the truck.
[SIZE=1]2015 Tundra Limited Crewmax, 4x4, Black
2003 Tundra V8, Black, Access Cab[/SIZE][SIZE=1] - 2002-2014 - Great truck!!
[/SIZE]
corc305 is offline
post #7 of 11 (permalink) Old 08-01-2014, 03:39 PM
tundra3400's Avatar
Garage
if you level and keep the same tires, you wont see much as a difference in MPGs. now adding bigger A/Ts ot M/Ts then yea MPGs go out the window.
2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 240,000 miles and counting, Husky Liners, 5K LED Heads & 5K LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs,
, K&N Air Filter,
, 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar
, Uniden PRO 520XL CB, 4in LED Reverse Lights
), 255/85r16 BFG KM2s, 3" LED flood cubes, 4" LED Hyperspot Pods, Custom TowHook Towball
Member
Other toys: FOR SALE: 1969 Torch Red Chevrolet Chevelle Malibu SS Convertible, 396, M21, 12 Bolt Posi 4.11s
tundra3400 is offline
post #8 of 11 (permalink) Old 08-03-2014, 02:45 PM
+1 here. You'll take a larger hit from the heavier tires than you will a level kit. I've been there and done that.
Now, the key is go buy lighter wheels with good tires and come out net or negative and you lessen the impact, but wider tires can offset that a hair due to wind resistance.
2005 Tundra Crew Cab 4x4 Limited | King Coilovers | Bilstien 5100 | Deaver AAL | BAMuffler | ARE Z Series Shell | Pioneer AVH-4000NEX | JL XD 700x5 | Polk MM Comps | JL Microsub | Alpine Backup Cam | WeatherTech Liners | NSR-4 Bike Rack | FN Wheels 5-star 17" w 285 Nitto Terra Grappler
characterzero is offline
post #9 of 11 (permalink) Old 08-04-2014, 06:19 PM
Das Jugghead
I would observe that wider tires hit fuel economy because they have higher rolling resistance as well as more rotational mass - the aerodynamic resistance would be negligible.
Good input from the members here - always nice to see some dialogue taking place.
post #10 of 11 (permalink) Old 01-21-2015, 02:54 PM
bryank's Avatar
my truck is leveled 2' with the Bilsteins and is currently rolling on 265/75/16 cooper AT3 tires. This was last weekend on a 300+ mile trip from charleston sc to Atlanta GA. All interstate and speeds between 75-80 most of the time. I just changed from 285/75/16 tires and would definitely agree that the tires you have will make a lot bigger difference in MPG than any type of lift will.
Highwaylizard likes this.
2004 Tundra AC 4WD V8--Bilstein 5100 set on 4th notch, BAMuffler, Pro Comp 16" Polished wheels, Dick Cepek FC-II 285/75/16
bryank is offline
post #11 of 11 (permalink) Old 01-21-2015, 04:04 PM
Originally Posted by bryank View Post
Attachment 64385
That 19+mpg is nice! How do you like the BAMuffler (I've got one ordered myself)? Feel like it helps with that fuel economy?
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
