new to offroading questions? - Toyota Tundra Forums : Tundra Solutions Forum
 1Likes
  • 1 Post By DevinSixtySeven
LinkBack Thread Tools
post #1 of 10 (permalink) Old 07-21-2014, 11:20 PM Thread Starter
Well went on my first 4x4 run on the weekend and loved it. I've done some logging roads and a bit off exploring before but this time went on an organized trip through some tight trails and creek and stuff I never been on before
I installed bilstein 5100s just after I bought the truck a few months ago
Question is what are some recommended things to make lessen the risk of breakdowns and stuff out there?
surreyjeff is offline
Sponsored Links
Advertisement
post #2 of 10 (permalink) Old 07-22-2014, 06:49 AM
Re: new to offroading questions?
A buddy in a second truck.
Tow Straps.
Smart decision making...
Listen Up Sonny is offline
post #3 of 10 (permalink) Old 07-22-2014, 12:11 PM
Leader of Group Evil
DevinSixtySeven's Avatar
Glad you enjoyed it! 1gen Tundras are very capable in the dirt.
This is a conversation you'll def want to have with your wheeling buddies.
First thing, never spin your tires unless you enjoy replacing axles and swapping differentials.
Air down. You can buy a CO2 tank, fixed regulator, hose, and chuck, for well under 200$. Some of us bought our own bottles, meaning we have to find a place which will refill and return our bottle. It may be easier and less expensive to use the bottle swap program at a welding supply.
If you still have open diffs (LSD may as well be an open diff, offroad), engaging the e-brake (rear axle) and feathering the brake pedal (mostly front axle) helps redistribute torque to the tires with traction.
Traction & bridging ladders. Under 200$ I think, and will get you out of sand, mud and snow.
Medium size D-handle shovel, long pry bar, saw, hatchet.
Cell phone, CB radio with tuned antenna.
That's the bare minimum.
-Sean
srjeff likes this.
1-Gen Tundra Offroad Technical FAQ Index
vs.
DevinSixtySeven is offline
post #4 of 10 (permalink) Old 07-23-2014, 07:01 PM
Sean266's Avatar
Let people know where you are and when you expect to be back
Bring a jacket
FRS radios (or CB) if going in a group
Shovel
Basic first aid stuff
Hopefully you can have someone join you that has a winch on their rig
Flashlight
Knife / firearm
Don't go at night
....never ever everrrrrr go alone.
Sean266 is offline
post #5 of 10 (permalink) Old 07-23-2014, 07:46 PM
Senior Contributor
tundrunk's Avatar
All great advice. I bring several pieces of wood (few 2x4, railroad tie, 4x4' plywood), compressor, tire plug kit, water, tools. One time I went out alone on a rainy weekend without my shovel, got high centered and had to dig my way out with a 2x4. I'll never take my shovel out of the bed again.
Best thing to bring is a companion.
"Drunk by noon but that's okay, I'll be President some day"
- Sublime
tundrunk is offline
post #6 of 10 (permalink) Old 07-26-2014, 09:15 AM
I would personally never use wood for vehicle recoveries. We wont even use logs on the trail because it's too light and can easily be destroyed with the power/weight from a vehicle.
Bare minimum I would say:
- Tire repair kit and a full sized spare
- tools for basic repairs
- recovery strap: a real one that has some stretch, NOT the cheapo nylon strap that act as rigid as a chain.
- D-Ring shackles
- recovery points mounted to the frame front and rear
- first aid kit
- air compressor or C02 setup
- a well maintained vehicle with no leaks
- Decent tires
- sliders if you want to avoid body damage - IMO the first piece of armor that you should own
- hi-lift jack
- some kind of communication device depending on the area your traveling in. A VHF Radio is the best. CB's and FRS are good for vehicle to vehicle communication but don't reach very far once in the mountains etc.
rickashay is offline
post #7 of 10 (permalink) Old 07-26-2014, 09:40 AM
2003bajatundra4x4ac's Avatar
don't forget if you do get stuck in sand (maybe mud-not much of that in Baja) let 1/2 of the air out of each tire and try to drive out. if you bog down let more out. i've gone down to +/- 12 pounds to get off a soft spot of broken shells along the high tide line with the water 20' away.
of course, you should be able to air back up! i've got an old SCBA tank and regulator for quick fills.
All you Baja lovers check out:
2003bajatundra4x4ac is offline
post #8 of 10 (permalink) Old 07-30-2014, 01:59 AM Thread Starter
Thanks for all the tips guys. I was on holidays and forgot i even started this thread. Lol
I have already started on the recovery gear to be safe and definitely won't be heading out alone
post #9 of 10 (permalink) Old 03-07-2015, 09:08 PM
I heard youre supposed to put a **** ton of air in the tires
2000fundra is offline
post #10 of 10 (permalink) Old 11-08-2017, 08:15 AM
If you are prepared and know what you are doing, going out alone is perfectly fine.
But as a beginner, I would agree that going out alone is probably not a good idea.
edit: Holy Necro Batman! Did not realize this was such an old post. This forum is not very active haha.
sportsmanjake is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
