Tow Hooks for 2WD Access Cab? - Toyota Tundra Forums : Tundra Solutions Forum
 1Likes
  • 1 Post By Rrumbler
LinkBack Thread Tools
post #1 of 7 (permalink) Old 09-24-2016, 09:30 AM Thread Starter
I have a gen 1, 2006 Tundra, 2WD Access Cab.
Was fortunate to have a friend pull me out of a tough spot when my rear wheels sunk into some very loose sand trying to go up hill. We ended-up borrowing a snatch strap from someone and was able to use some less than ideal hooks to attach to the bottom of the truck. The manual states to use the emergency eyelets under the front of the vehicle, which we did use, however I'm heading back into similar country and want to be better prepared. On four wheel drive vehicles, the manual states that there is an emergency towing hook.
I looked underneath the truck today to see if I could add one of those as it would have been much easier to hookup the snatch strap to that instead of what we have done, but it doesn't appear that there are any holes to hookup a standard tow hook there.
Can someone please confirm if that is true?
If the eyelets are all I have, does anyone have a suggestion?
Has anyone used a clovis hook or fashioned one to fit in there? If so how did you do it as the eyelets look irregular.
If not any other ideas would greatly be appreciated!
Thanks for any future feedback
tundratalker is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 09-24-2016, 12:30 PM
cheapskate's Avatar
Re: Tow Hooks for 2WD Access Cab?
I thought tow hooks were standard on every truck, guess not. Check some local scrap yards. Its not a high demand item so you could probably get them cheap.
2012 Crewmax TRD 5.7, 4x4, 15% tint all around plus sunstrip. Ionic Gladiator running boards. Weathertechs front and rear. Line X, AVS vent visors. Viper 5301 2 way remote start, MBRP S5316304 cat back exhaust. Bakflip Fibermax tonneau cover.
Traded in my 05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner, Rampage Patriot running boards.
cheapskate is online now
post #3 of 7 (permalink) Old 09-24-2016, 01:22 PM Thread Starter
Thanks - what's weird is the Toyota dealer looked-up my Vin and they're saying it's not an option. However, when I look at what's underneath the truck, it looks like a hook can be installed on top of the eyelets/bracket, with just a longer bolt.
Anyone know if that's true?
post #4 of 7 (permalink) Old 09-24-2016, 02:05 PM
Get a couple of good quality screw pin shackles that fit snugly into the eyes on your truck; takes more time to hook up, but much more secure.
DevinSixtySeven likes this.
Rrumbler - Tired, re-tired, and just generally wore out. Wrenching and banging on stuff for over sixty years.
Rrumbler is offline
post #5 of 7 (permalink) Old 11-16-2016, 09:32 AM
I know I'm two months late. I'm not sure if the bolt spacing is the same or not but give them a call to see if these are standards.
Tow Hook - Heavy Duty w/ Safety Clip 8pc Chrome Finish --- NEW : Chrome Tow Hook & Chrome Recovery Hook
IVexample is offline
post #6 of 7 (permalink) Old 01-11-2017, 10:38 AM
Leader of Group Evil
DevinSixtySeven's Avatar
The factory tow hook does indeed mount over the loop, with longer bolts.
Personally, I'd suggest Rrumbler's solution over all others. A clevis fits fine through the loop...any ranch supply should carry a variety. Use the largest pin which will fit through that loop.
1-Gen Tundra Offroad Technical FAQ Index
vs.
DevinSixtySeven is offline
post #7 of 7 (permalink) Old 01-13-2018, 12:41 AM
I went with a pair of stainless steel oval-shaped quick links in the eyelets. I also got a D-ring shackle hitch that goes in the receiver for the rear.
VT Mike is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
