4wd shifter and button - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 3 (permalink) Old 07-31-2018, 09:04 PM Thread Starter
PLEASE HELP!!! I just got a 2001 tundra ltd and although it is automatic ,it has a shifter for four wheel drive but it also has buttons (4 lo/4 high) my 2002 tundra had only buttons and I can't figure out how to get it into 4wd! I want to go camp at a 4 wd only beach tonight
allison is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 08-06-2018, 02:04 PM
dyogim's Avatar
Garage
Re: 4wd shifter and button
Did you buy this truck used? If so, the previous owner swapped out the ADD transfer case for a manual one. You'll be able to engage the transfer case, but it means nothing if you can't engage the ADD in the front diff. It's possible the previous owner integrated a switch to engage the front diff. Is there a unique switch anywhere on the dash?
Another option if it's set-up the way I'm thinking, try shifting the lever into 4HI, then press the 4HI button. See if that engages the front diff. For 4LO, you'll only need to engage the lever.
~Mike
SAC'ed 2000 V8 tundra - http://dyogim.blogspot.com
dyogim is offline
post #3 of 3 (permalink) Old 08-07-2018, 09:55 AM
I've read elsewhere on the push-button only versions (no hand shifter) it could also be the mechanism on the exterior of the transfer case itself (that physically switches it to 4WD) that gets jammed (especially if not used / engaged in a while). It is a common problem, but not sure if there is a similar mechanism on yours.
There is also a vacuum hose on the very top -- make sure that is connected and check your electrical connections on the transfer case as well.
jestersmith is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
