Starter keeps running even with relay removed - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 2 (permalink) Old 06-15-2018, 01:18 PM Thread Starter
So I went to tow a 94 Celica from my sister's house to my house. My sister said it made a god-awful noise when she tried to start it one morning and it remained running even when she took the key out. So when I go to jump it, it instantly starts cranking when I hook up the jumper cables. I pulled the starter relay thinking that would cut the circuit, but it starts cranking even with the relay removed. Does anybody know how this circuit operates? Should I go straight to changing the starter (bad solenoid) or change the ignition switch? Or the relay? I don't want to just throw money at it I'd like to pinpoint the problem if possible... any help out there? Thanks
Sent from my Pixel using Tapatalk
bitoboy is offline
Sponsored Links
Advertisement
post #2 of 2 (permalink) Old 06-15-2018, 02:13 PM
DJ
Re: Starter keeps running even with relay removed
It's a classic symptom of a stuck starter solenoid.
You can disconnect the big +12 cable from the solenoid, then connect the jumper cables again. If the key circuit is stuck closed, then you'll hear a big "click" from the solenoid when it engages. It won't start, as the solenoid cannot put current through the starter with the +12 cable disconnected. This will tell you if it's the solenoid (it doesn't "click") or the key circuit (it "clicks").
DJ is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
