Search "
" across the entire site
Search "
" in this forum
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Menu
Log in
Register
Home
Forums
Technical Forums
Suspension & Axle
Follow Forum
Start Discussion
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
2
3
Go to page
Go
34
Next
1 of 34
Go to page
Go
Last
Why most spacer lifts are bad....
jzaiden
May 19, 2008
8
9
10
183
98K
5 h ago
by
Farnsrocket
Dobinson springs for Gen 2 Sequoia 4 sale
jmb54
14 d ago
1
213
3 d ago
by
rdubs20
J
2005 Sequoia Rear Differential Swap
Jessem
2 mo ago
0
260
2 mo ago
by
Jessem
B
Growling cyclical noise from front end
bbodenstein
Apr 9, 2008
17
43K
2 mo ago
by
gscamman67
8
Concerns with My New RC 3.5” Lift
8trek
3 mo ago
0
454
3 mo ago
by
8trek
B
Coil spring compressor
broncobird
Feb 3, 2007
11
8K
3 mo ago
by
cimahar
N
2012 4WD DBL Crew Level Question
NV Mike
4 mo ago
1
262
4 mo ago
by
Arjunpulika
06 tundra sr5 no sound thru speakers
Gnovs
4 mo ago
0
188
4 mo ago
by
Gnovs
2017 tundra lifted 6" with ProComp kit and full length ProComp Coil Overs and it rides very rough need help
DustyTundra
4 mo ago
10
645
4 mo ago
by
DustyTundra
Shocks leaking after 55k miles
colin.k
8 mo ago
1
294
5 mo ago
by
rydllan
S
Cost of swapping strut coilover springs?
spacebanjo
5 mo ago
1
312
5 mo ago
by
festerw
T
Clunk after lift
TomPrickett
7 mo ago
3
774
5 mo ago
by
Chappy R
PSA RECALL on 6-Ton Jack Stands from Harbor Freight
aggreX
11 mo ago
3
570
8 mo ago
by
aggreX
A
Finally installed my lift....how it went & what I did.
afkeatng3
Sep 17, 2007
8
4K
9 mo ago
by
ProX270
S
2013 Sequoia Platinum Rear Shock Install Help
Sprech
9 mo ago
1
362
9 mo ago
by
Sprech
E
Front drivers side cv axle after ecgs bushing install
ECTJT
10 mo ago
0
384
10 mo ago
by
ECTJT
T
Aftermarket front shocks for 06 Sequoia with rear air suspension
TominKY
Jul 17, 2019
10
1K
10 mo ago
by
TominKY
P
Dash lights after changing struts
Pwojton
Apr 15, 2019
3
1K
Feb 23, 2020
by
Washington hunter
Can you remove the overload spring to soften the ride?
BAMAJAS
Jun 17, 2008
13
18K
Nov 5, 2019
by
keithbickford
T
Installed Icon expansion pack
timmyb19
Nov 24, 2018
2
3K
May 25, 2019
by
ktmracer01
J
Who here has Re-Geared their Tundra for larger wheels & tires?
justdifferentials
May 15, 2019
0
1K
May 15, 2019
by
justdifferentials
C
PS hoses blowing apart
Cayuse365
May 8, 2019
0
709
May 8, 2019
by
Cayuse365
U
2013 Sequoia Rear Air Ride Not Level. Help!
Unistang
Aug 6, 2017
3
1K
Apr 3, 2019
by
omgboost
W
Will standard coil over fit TRD
Wayne Bowlby
Feb 24, 2019
1
839
Mar 23, 2019
by
ebenke
2013 Lowered Tundra
Dennis Romero
Mar 21, 2019
0
623
Mar 21, 2019
by
Dennis Romero
R
Should I add a leaf spring?
Rzrbrn
Feb 4, 2018
1
1K
Mar 7, 2019
by
Shurup
K
2007 Crewmax TRD shocks
Kabic
Feb 19, 2019
0
668
Feb 19, 2019
by
Kabic
B
Fox Coil Over 2.5 w/ Reservoir issues
benw
Jan 9, 2019
3
1K
Jan 19, 2019
by
HBjeff
S
Any Tundra TRD Pro owners in Hawaii?
Sneaky7980
Jan 1, 2019
0
431
Jan 1, 2019
by
Sneaky7980
F
2018 Tundra best 3 1/2 lift kits
FoxtrotCharlie
Dec 17, 2018
0
971
Dec 17, 2018
by
FoxtrotCharlie
S
Tundra carrier bearing
sikkenx
Oct 30, 2018
0
752
Oct 30, 2018
by
sikkenx
P
06 Tundra bad shake braking at high speeds-solved Wheel Cylinders
Paul Wood
Oct 13, 2018
2
879
Oct 16, 2018
by
Don Tibbetts
J
5100 with Quick-strut springs?
Jfelton
Oct 11, 2018
2
1K
Oct 11, 2018
by
festerw
C
02 Tundra Rusted Differential Leak
CincyTundra
Oct 8, 2018
0
644
Oct 8, 2018
by
CincyTundra
Squeaking noise on acceleration from a stop
Chamoru
Sep 27, 2018
2
2K
Sep 28, 2018
by
Chamoru
1
2
3
Go to page
Go
34
Next
1 of 34
Go to page
Go
Last
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Suspension & Axle
Technical discussions regarding alignment, stock and modified suspensions, lift kits, axles, hub conversions, gearing and steering.
7.7K
posts
3.3M
views
Join Community
Forum Staff
View All
Highwaylizard
Moderator
Top Contributors this Month
View All
R
rdubs20
1 Reply
F
Farnsrocket
1 Reply
jmb54
1 Reply
Join now to ask and comment!
or
sign up with email
Home
Forums
Technical Forums
