in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
Menu
Log in
Register
Home
Forums
Tundra Forums
1Gen-Tundra
Suspension, Axles, Brakes
Follow Forum
Create Post
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Lifting
Kits, tire fitment, gear ratios, general discussion and advice on lifting your 1gen Tundra.
15.3K
5M
2 mo ago
15.3K
5M
2 mo ago
Lowering
Drop kits, air bags, general lowering discussions for your 1gen Tundra.
713
369K
Jan 22, 2022
713
369K
Jan 22, 2022
1Gen-Steering System & General Handling
Steering components, payload handling, swaybars, and other hardware. Please post alignment discussions under "Tire, Wheel, Alignment".
3.6K
1.6M
22 d ago
3.6K
1.6M
22 d ago
T-Case, Driveshaft, Diff, Axle, Hub
Hub, axle, CV boot & joint, driveshaft, differentials, transfer case. Maintenance, repairs, and upgrades. Everything from restoring rusted axle housings to installing manual hub kits or wheel lugs.
8.6K
4.8M
3 d ago
8.6K
4.8M
3 d ago
1Gen-Brakes
Brake maintenance, ABS, VSC, upgrades.
9.2K
6.1M
24 d ago
9.2K
6.1M
24 d ago
Filters
Show:
Loading…
1
2
3
Go to page
Go
28
Next
1 of 28
Go to page
Go
Rear brake Proportioning Valve
BroHon
8 d ago
1
140
8 d ago
by
Mr.Bee
2000 Tundra Rubber Body Mounts
RyGuy72
10 mo ago
11
1K
17 d ago
by
BDiefAZ
W
Drive shaft coupler movement.
Wild duk
25 d ago
10
444
21 d ago
by
BroHon
N
Grease cast-off around CV joint, Boot not damaged. What should I do?
NW Tundra
2 mo ago
11
952
26 d ago
by
Professional Hand Model
J
Leaf Springs question
JKLedbetter
1 mo ago
0
166
1 mo ago
by
JKLedbetter
Hard brake pedal with high revving motor
Oldhead
3 mo ago
1
451
3 mo ago
by
BroHon
T
1st Gen Ride Quality: How to Improve the ride quality
tariqansari
4 mo ago
10
1K
3 mo ago
by
Chappy R
E
Realistically how hard are 1st Gen UCA’s to remove?
EricZ
3 mo ago
3
488
3 mo ago
by
festerw
Welding front knuckle
Gasman675
4 mo ago
2
389
4 mo ago
by
Gasman675
Engine noise filtering through torn steering shaft boot?
Leathernuts
Mar 26, 2006
6
7
8
149
98K
5 mo ago
by
MasterB
K
Height control compressor not kicking on
Kedmon
5 mo ago
0
284
5 mo ago
by
Kedmon
Suspension clunk
makethedrop
Oct 13, 2021
4
1K
5 mo ago
by
BDiefAZ
C
Abs axle shaft vs non abs axle
crownapper
5 mo ago
0
347
5 mo ago
by
crownapper
T
2002 Tundra V8 Front Struts and Shocks.
tariqansari
Nov 23, 2019
3
4K
5 mo ago
by
tariqansari
E
Am I overthinking this? What shape are stock Tundra front sway bar link bushings? Cylindrical or tapered?
EricZ
6 mo ago
4
689
6 mo ago
by
RUSTYNUTS
E
Lucas Green HD grease out of stock everywhere? What is compatible?
EricZ
6 mo ago
3
935
6 mo ago
by
2007 tundra 6inch lift
831Luke
7 mo ago
0
370
7 mo ago
by
831Luke
N
2004 Tundra Suspension Replacements
ndknoy
Jan 1, 2022
4
2K
9 mo ago
by
Davido49
R
SPC ball joint worn out, NO WARRANTY
rusterfarian
10 mo ago
3
1K
9 mo ago
by
Chappy R
2WD/4WD Front Strut Interchangeability
JacobBosarge
9 mo ago
0
503
9 mo ago
by
JacobBosarge
KYB front new struts
RyGuy72
12 mo ago
2
783
10 mo ago
by
RyGuy72
Help - Rear differential noise
H2O_MAN
Oct 9, 2014
7
10K
11 mo ago
by
pirates712
Sequoia brake issues
Slimles
11 mo ago
2
805
11 mo ago
by
RyGuy72
E
What is this?
entsurv
Jan 8, 2022
1
762
Jan 8, 2022
by
cheapskate
J
2001 Toyota Recall Frame/Brakes
jsb1996
Oct 18, 2021
8
2K
Jan 2, 2022
by
festerw
V
Steering wheel/steering column play
vespax4
Jan 20, 2004
11
8K
Dec 12, 2021
by
Sequoia 346k
B
stabilizer bar end link 2006 tundra 4wd
bantley19
May 31, 2021
2
1K
Dec 6, 2021
by
H2O_MAN
Truck lean / New Leafs and shocks
makethedrop
Dec 1, 2021
0
494
Dec 1, 2021
by
makethedrop
cracked brake line
bucpaulie
Oct 11, 2021
3
949
Oct 28, 2021
by
bucpaulie
M
Front end noise/rattle when going over bumps
macinjosh
May 10, 2018
17
24K
Oct 13, 2021
by
dport4short
P
2003 Tundra 4X4 not engaging
pewtherer
Jan 21, 2012
11
18K
Oct 4, 2021
by
ron nakama
Discovered the source of the mysterious front end clunks
Sketti0
Oct 2, 2020
4
2K
Sep 24, 2021
by
alltracman78
Lower Ball Joints
makethedrop
Sep 20, 2021
7
2K
Sep 22, 2021
by
Chappy R
B
Old man emu
Backwoodsman
Sep 17, 2021
0
538
Sep 17, 2021
by
Backwoodsman
ABS grabbing??
TwinStop
Dec 9, 2004
5
1K
Sep 15, 2021
by
MarkFC
1
2
3
Go to page
Go
28
Next
1 of 28
Go to page
Go
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Stock and modified suspension, lifts, lowering kits, handling improvements, CV joints, axle and driveshaft maintenance, repairs, and upgrades.
Show more
45.4K
posts
21.4M
views
Join Community
Grow Your Business
Forum Staff
View All
jamesjr4750
Super Moderator
Remmy700P
Super Moderator
Admin
Administrator
Top Contributors this Month
View All
W
Wild duk
S
smokamoto
Recommended Communities
Toyota Off-Road Forum
170K+ members
Toyota Tacoma Forum
63K+ members
2024+ Toyota Tacoma Forum
80+ members
Join now to ask and comment!
or
sign up with email
Home
Forums
Tundra Forums
1Gen-Tundra
