Bilstein 6112 60mm Front Shocks for my 2006 Tundra Access Cab 4x4 - Toyota Tundra Forums : Tundra Solutions Forum
 7Likes
  • 3 Post By SoCalPaul
  • 2 Post By SoCalPaul
  • 2 Post By bullminner
LinkBack Thread Tools
post #1 of 14 (permalink) Old 03-25-2017, 11:00 PM Thread Starter
SoCalPaul's Avatar
Garage
I'm starting a new thread because these actually exist now & I have them in my hot little hands. This will be my build thread. Due to scheduling conflicts, it will probably be at least a few weeks before I can tackle this.
I ordered these off Amazon ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) & as you can see, my shocks weren't supposed to be delivered for another week or 2. They arrived today! They do not include a top plate so I ordered a pair of Moog plates, which should be here tomorrow. The first picture is what is included x2. The last pic is the 6112 next to a 5100. Looking forward to getting these installed.
I've had good luck with Bilsteins over the years, I like the ride they've given me. I only do light off-roading. I use this truck for my daily driver work truck & I often have to use parking garages, so 1-1.5 inch lift is all I feel comfortable with.
P/N 47-260337 for 2000 - 2006 Tundra front only. No part number listed for the rear.
Lift : 1" max for Access Cab, 2" max for DC.
Product page: Bilstein, Innovation and High Quality Since 1873
Instructions: http://cart.bilsteinus.com/pdfs/E4-WM5-Y509A00_0.pdf
2006 Tundra, AC, V8, Ltd, 4wd, Bilsteins, White
2004 Tundra, AC, V8, SR5, 2wd, Bilsteins, Green - Side swiped
1993 L C, Awd, Frt Ctr & Rr Lockers, Bilsteins, Burgandy
1994 4Runner, V6, Ltd, 4wd, Perf Prod Prog 2" lift springs, Bilsteins, Graphite - Hit while parked
2001 Tundra AC, V8, Ltd, 4wd, Perf Prod Prog 2" lift springs, Bilsteins, White - Sold
1992 4Runner, Sr5, V6, 4wd, Torsion bar/Downey OR rr lift 2", Rancho shocks - Trade-in
1988 Toyota P/U AC, 4 cyl, 4wd, 2" lift - Sold
SoCalPaul is offline
Sponsored Links
Advertisement
post #2 of 14 (permalink) Old 04-10-2017, 11:30 PM Thread Starter
SoCalPaul's Avatar
Garage
Re: Bilstein 6112 60mm Front Shocks for my 2006 Tundra Access Cab 4x4
Well, I got the rear 5160s for my Tundra today. Here it is compared to a standard 5100.
SethNautique and MtnClimber like this.
post #3 of 14 (permalink) Old 07-21-2017, 12:23 PM
any updates on ride quality or install , and generally how you like them?
atjSanz is offline
post #4 of 14 (permalink) Old 01-30-2018, 07:56 AM
bump - where's the review?
2005 Tundra Crew Cab 4x4 Limited | King Coilovers | Bilstien 5100 | Deaver AAL | BAMuffler | ARE Z Series Shell | Pioneer AVH-4000NEX | JL XD 700x5 | Polk MM Comps | JL Microsub | Alpine Backup Cam | WeatherTech Liners | NSR-4 Bike Rack | FN Wheels 5-star 17" w 285 Nitto Terra Grappler
characterzero is offline
post #5 of 14 (permalink) Old 02-10-2018, 06:54 AM
Garage
BUMP - Looking to do the same lift on my 2006 DC
mrwright is offline
post #6 of 14 (permalink) Old 03-27-2018, 01:11 PM
I just did the 6112's on the front and 5160's on the rear. I love them. I have them on the 4th notch. Only issue right now is my sway bar is disconnected so I can replace all the bushings. Took it in for a new alignment and they can't get a right pull out of it. I think I may have to replace the upper control arms. My tires used to be fine and then I had both lower control arms with ball joints replaced and my front tires started rubbing. I think new upper control arms will help fix the alignment.
speedtre and SC T100 like this.
bullminner is offline
post #7 of 14 (permalink) Old 03-29-2018, 05:27 AM
Garage
Bullminner,
Could you upload a picture of your current UCA with the truck on the ground? I'd like to see what kind of angle this lift puts on them.
mrwright is offline
post #8 of 14 (permalink) Old 03-29-2018, 07:42 AM
I had the same alignment issue with 5100's and new OME springs. Bought the SPC arms and they were able to dial the alignment in easily.
festerw is offline
post #9 of 14 (permalink) Old 04-15-2018, 06:47 AM
I had some 5100's on the front for the last 4-5 years on my 05 DC. Now both are blown after 25k miles of use. I'm reading your thread and wondering what you think? Im going to put some 5100's on the rear, because I already have a new set. I was also going to replace the ball joints, but didn't want to touch the arms. Thoughts?
skippy1999 is offline
post #10 of 14 (permalink) Old 04-25-2018, 09:19 PM
Senior Contributor
tundrunk's Avatar
You'll need to "touch" the arms for upper or lower ball joints. Won't have to remove the arms though.
This set up looks sweet.
"Drunk by noon but that's okay, I'll be President some day"
- Sublime
tundrunk is offline
post #11 of 14 (permalink) Old 04-06-2019, 12:48 AM Thread Starter
SoCalPaul's Avatar
Garage
Well, It's been awhile. Unfortunately I've had some health issues that have slowed me down some.
I finally got my Bilstein 6112 front and 5160 rear shocks installed about 6 months ago. I set the fronts at Bilstein's recommended max height for my Access Cab 4wd. I got about 1.25" of lift, but my starting point was a cheap aftermarket replacement shock & spring set. On the rear I added Wheeler's Offroad 1.5" add-aleaf springs. The ride is excellent on the street. I haven't been offroad yet. As seems typical for me, shortly after installing the shocks & springs, someone hit the front of my truck. Also a couple of hundred miles after the install, my CV boots started leaking.
When I finally was able to change the boots, I found that the previous owner had installed non-Toyota CV shafts, so the boots I had didn't fit properly. So after some thought, I ordered new Toyota CV Shafts, upper & lower ball joints & tie rod ends. That's my next project. I'm still not up to snuff, so it will likely be a slow process.
Anyway here's some pics of the install.
1: Bilstein 6112 front shock & spring.
2: Bilstein front 5100 vs 6112.
3: Bilstein rear 5160 vs 5100.
4: Bilstein 6112 vs Monroe Shock & spring.
5: Bilstein front 6112 installed.
6: Bilstein rear 5160 & Wheeler's add-a-leaf installed.
post #12 of 14 (permalink) Old 04-12-2019, 12:45 PM
Thanks for the update!
2005 Tundra DC SR5 TRD LSD 4WD
speedtre is offline
post #13 of 14 (permalink) Old 04-17-2019, 08:38 AM
SethNautique's Avatar
How much lift did the Wheelers AAL get you with the overload leaf removed? How does it perform with weight in the bed without the overload? I have those AAL's in my garage waiting to go on but cant decide if I want to leave the overload or not.
SethNautique is offline
post #14 of 14 (permalink) Old Yesterday, 10:12 PM Thread Starter
SoCalPaul's Avatar
Garage
I got about 1.25 inches of lift. I run with a fiberglass shell a probably 100 pounds or so of "stuff" in the back. I haven't really run with any weight. They are supposed to be progressive & the instructions say to remove the overload springs. If you run a lot of weight you might want to leave them in the pack.
This is the set I used
https://wheelersoffroad.com/i-254903...tegory:1387397
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
« Abs brake issue | - »
You may post new threads
You may post replies
