Engine noise filtering through torn steering shaft boot? - Page 10 - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #136 of 149 (permalink) Old 04-17-2012, 12:54 PM
D41
Re: Engine noise filtering through torn steering shaft boot?
A little confusion, I'm about ready to do mine 2000 tundra, reading this & other threads is the 2000 a little more involved more disassembly than later models?
For some reason I can't see most of the pics in this thread.
Thanks,
D41 is offline
Sponsored Links
Advertisement
post #137 of 149 (permalink) Old 06-06-2012, 10:46 AM
Originally Posted by mustang67408 View Post
I take the inner cover off (3 bolts) by the drivers feet, then carefully knocked the bushing down.
Can someone post a picture and maybe some more detail explaining this?
I just checked mine last night, and sure enough its completely torn. It looks pretty clean and rust free from underneath, so I'm hoping that goes smoothly, but I'm confused about getting the bushing loose.
spleck is offline
post #138 of 149 (permalink) Old 10-14-2014, 07:31 PM
Hi everyone...bumping an old thread. I've searched the forum several times but still have a few questions. Hopefully someone with a similar year can help me out.
I recently bought a 2004 DC SR5 TRD Off Road from my boss. It has the steering rack boot tear that this thread focuses on repairing. I've read the Sequoia thread with pics and instructions but there seems to be a difference in the assemblies from 2004 and on.
Here is a pic from inside the cab of my truck of the "upper" steering shaft and torn boot. I have come to understand that I do not need to disassemble anything beyond what is already pictured up here.
Here is a pic from under the center of the truck looking forward with the wheels straight. I believe that I need to remove the upper bolt and loosen the lower one. Is that correct? Then I can pry the coupler (the thing with the "upper bolt" going through it) up the splines in the intermediate shaft and then off the intermediate shaft. Is that the correct procedure? Once off, I then punch the boot down the intermediate shaft from inside the cab and replace with the new one greased up. I understand that I should make lines on both the coupler and intermediate shaft splines so that I can properly line them up upon reassembly.
How can I pry the "coupler" up and off if I don't remove the nuts/bolts on the base?
Am I going down the right path or am I going to mess up my new (new to me) truck? Thanks and as you can tell I'm still learning...or at least trying to learn.
--Brent
File Type: jpg Showing the coupler is not seperate.jpg (92.5 KB, 143 views)
bmurray is offline
post #139 of 149 (permalink) Old 10-18-2014, 07:09 AM
Bump for much needed help. Thanks!
--Brent
bmurray is offline
post #140 of 149 (permalink) Old 10-30-2014, 08:50 PM
Anybody??? I'm going to try fixing tomorrow. Would really appreciate some wisdom. Thanks in advance.
bmurray is offline
post #141 of 149 (permalink) Old 10-31-2014, 08:41 PM
Not sure, I have to do mine as well.
Need to do some more reading.
Hopefully someone will chime in.
rdog is offline
post #142 of 149 (permalink) Old 11-03-2014, 08:31 PM
what did you end up doing?
rdog is offline
post #143 of 149 (permalink) Old 11-04-2014, 09:44 AM
I ended up removing the top bolt on the "coupler". I was unable to detach the steering shaft though. Then I ran out of time and had to reassemble everything. Going to try again this weekend hopefully. I'm not much of a mechanic but I'm trying to learn on the tundra.
bmurray is offline
post #144 of 149 (permalink) Old 11-08-2014, 05:52 AM
Leave the wheels on the ground and make sure they're straight
Bungee the wheel straight
PB Blaster on the lower pinch
On the inside floor, take off the Cover over the rag joint, 10mm
Mark the relationships of the pinch to the shaft
Remove the pinch bolts and open the pinch with a small chisel, 12mm
Drop the steering column, before doing this remove the negative battery cable, no need to dismantle the airbag and all, your just dropping the column, so lower plastic covers will have to come out
Once your column is down you should be able to get it out.
Wiggle out the shaft, which ever one, upper or lower, an air hammer on the lower pinch would be awesome Just to loosen the rust.
Swap the boot out
Spray the boot with some white lithium grease and reinstall it all
T
Sent from AutoGuide.com Free App
TonyDZ is offline
post #145 of 149 (permalink) Old 11-08-2014, 05:53 AM
DONT SEPARATE THE RAG JOINT, Drop the column
T
TonyDZ is offline
post #146 of 149 (permalink) Old 11-11-2014, 10:50 AM
Leader of Group Evil
DevinSixtySeven's Avatar
Reminds me, I need to do this myself. Thanks for the tips.
1-Gen Tundra Offroad Technical FAQ Index
vs.
DevinSixtySeven is offline
post #147 of 149 (permalink) Old 03-13-2016, 07:07 PM
BlueRanger's Avatar
Send a message via AIM to BlueRanger
TTT!
Just discovered this thread after putting Doug Thorleys on my truck. Could not believe I still had a driver side manifold leak, especially since the stock ones did show any cracking. Scratching my head I found this thread. Took a quick look, GAPING hole. Will replace this week and report back, no doubt this was the problem in the 1st place.
Good news, I got some power
Bad news, wasn't 100% necessary
Will report back when I get it fixed, doing the steering coupler/joint since its been on the truck for 12 years....
This thread should be a sticky, has the potential to save others a lot of $$$ if they don't want to shell out for headers (and labor, what a PITA to put on).
04 Tundra, Hoes, Uni's, Spintech, 285s + other misc. bling items.
BlueRanger is offline
post #148 of 149 (permalink) Old 03-25-2016, 07:34 PM
BlueRanger's Avatar
Just replaced it, problem fixed, BRAND NEW TRUCK, incredible. One local dealer wanted $45, the next one wanted $16.
Easy to do, my pearls from instal comments above:
-Wheels straight on ground
-Rock the wheel until it does the security lock
-Remove driver splash guard, spray PB blaster on splines where it connects to steering coupler just above rack, soak it down. Then wash your truck while you let it work its magic.
-Undo top and bottom pinch bolt for steering coupler
-Make sure to mark bottom steering coupler to rack connection point. Sharpie didn't work too well, had to make an educated guess, I got lucky.
-Push up on coupler until its free of rack, then remove all together.
-Pound out old bushing, it will fall out bottom.
-Pound new bushing in, make sure to grease liberally
-Reassemble everything.
post #149 of 149 (permalink) Old 12-16-2018, 12:23 PM
Similar for tundra / sequoias?
Whocares2 is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
