No mods wheel fitment - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 14 (permalink) Old 02-08-2017, 10:54 AM Thread Starter
I have an 06 double cab and am wanting some wheels, my question is what off set should I get so I will not have to do any modifications to my truck. I don't want to cut anything and would like wider tires. Any advice would be appreciated. Thanx
irastoy is offline
Sponsored Links
Advertisement
post #2 of 14 (permalink) Old 02-08-2017, 10:58 AM Thread Starter
Re: No mods wheel fitment
I'd like to go with a 17" or 18" wheel.
irastoy is offline
post #3 of 14 (permalink) Old 02-08-2017, 07:58 PM
The stock 17" Tundra wheels are 7.5" wide, +18mm offset.
Are you looking for OEM Toyota wheels, or aftermarket? The latest 4Runner wheels bolt right on, and have +15mm offset....I'm mounting up a set on my '06 Double Cab tomorrow.
'06 DC - Phantom Gray
Purchased Jan 2015 with 17,500 original miles! - Gently used "grocery getter" for a little old lady in California.
rc05293 is offline
post #4 of 14 (permalink) Old 02-08-2017, 09:41 PM Thread Starter
Let me know if you have any rubbing,that my concern.
irastoy is offline
post #5 of 14 (permalink) Old 02-08-2017, 10:52 PM Thread Starter
I would like some wider tires like maybe 10,or 12 inches. I'd settle for 9 but the stock seems narrow to me.
irastoy is offline
post #6 of 14 (permalink) Old 02-08-2017, 11:39 PM
Everything should fit unless you're thinking about steel wheels but I doubt you are.
Just ensure that you get the right spoke pattern for your model and you have a backspace of 18+ or less. My recommendation is 0 to -10. They give the trucks a wider stance and more flush with the body looking from the side.
Tires come to the question when you're questioning fit. I'm sure you can find easy threads about max width and height for the tire/wheel combination you're wanting.
As for the 10-12 inch wide wheels. No. Unless you have a 6inch lift they're very unnecessary and basically look goofy IMO. An 18x9 with -10mm offset with at least 4.5 backspacing with a 285/55/18 tire will give you the wide stance you're looking for.
Bryson James is offline
post #7 of 14 (permalink) Old 02-08-2017, 11:40 PM Thread Starter
Thank you very much.
irastoy is offline
post #8 of 14 (permalink) Old 02-14-2017, 08:25 PM
Ok now I'm curious - what difference would steel wheels make? I'm considering pro comps for my 03 Tundra, if I don't get 2017 OEM Tacoma wheels.
Colemic is offline
post #9 of 14 (permalink) Old 02-15-2017, 11:39 PM
From what I've read steel wheels don't have the correct backspacing needed for our trucks
post #10 of 14 (permalink) Old 02-20-2017, 05:50 AM
I just replaced the stock 17" wheels on my '06 DC....I was planning to give my old ones to my father in law for his truck, but he's old school, and likes the steelies.
Where are you located? If you're interested in buying my stock 17's, I can make you a good deal on them. :-)
Send me a PM with your contact info, and I'll send you some pictures.
rc05293 is offline
post #11 of 14 (permalink) Old 02-22-2017, 06:04 AM
cary970's Avatar
Garage
So will a aftermarket wheel with backspace of 5 and zero offset work. I always hear 4.5bs is magic number. And the guy at 4x4 shop says that -12 to - 1 will fit but I don't trust that guy haha this is rim I'm thinking about. With 5100s and 285/70/17 tires 17/9 rim
cary970 is offline
post #12 of 14 (permalink) Old 03-11-2017, 11:49 AM
SoCalPaul's Avatar
Garage
I don't think the 285 will fit on stock height without rubbing. I used to have a 2001 Tundra AC, Limited, 4x4. I installed 285/75/16 BFG AT on the TRD Ivan Stewart rims (0 offset I believe) & they rubbed at full lock going up driveways. (rear outer side of the front wheel well & lightly on the front frame area. I installed Performance Products progressive rate front springs which gave me about a 1 3/4" lift. I didn't have any rubbing issues after that.
SoCalPaul is offline
post #13 of 14 (permalink) Old 06-27-2017, 07:26 AM
What size tires are you running on those snowflakes? I have stock 17's and looking to change them out, but I believe the snowflakes are 7" rims while the stocks are 7.5". I'm running 265/65/17 now.
Thanks in advance.
Rick
restorick is offline
post #14 of 14 (permalink) Old 08-29-2017, 10:45 AM
Thanks in advance.
Rick
Sorry for the late reply.....didn't see the notification that you'd quoted my post.
Tires are 265/65-17's. They're the Toyo Open Country dealer take-offs from a '17 Tacoma.
The wheels are from a '17 4Runner.....backspacing is only 3mm difference, not 1/2".
The Tacoma wheels are the ones that have the deeper offset, and could cause rubbing. 4Runner wheels are pretty much a straight swap.
rc05293 is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
