DIY: LED Puddle Lights - Toyota Tundra Forums : Tundra Solutions Forum
LinkBack Thread Tools
post #1 of 73 (permalink) Old 08-21-2009, 10:03 PM Thread Starter
VooDooDan's Avatar
Here is a DIY for LED's in the puddle lamps for the Limited tundra.
LED's were bought from VLED's. They are a PCB board with 6leds and come with different type of connectors. The small festoon one is the perfect fit for the tundra puddle lamps.
Link to the them: Here
1st step would be to cut around the puddle lamps to get the plastic lose from the clear cover. Once you cut all the way around you can use a small flat head screw driver to carefully pry the lens off.
Then take the old bulb out and place the new festoon with connector in for the LED light.
Then glue or use double sided tape to place the LED on the festoon connector to stay in place. You might also have to cut off the 2 long holders that hold the old festoon bulb in.
Then glue the clear lens back onto the black housing.
Then install the lamp back into the truck.
2008 Tundra 5.7 4x4 LTD Silver w/Navi, XM, & Memory
TRD Rear sway bar, VLED Cab lights, Longo LED Tail lights, Recon LED CCL's
GTek DSP, Custom LEDs for rear seats, LED Puddle lamps, Duplicolor Bed Armor
Toyota Painted Fender flares, Painted Door Handles w/LED's
Magnaflow Dual CAT Back, AFE Cold Air, Bilstein 5100 front/back
Procomp 8128 18in w/285 65 18 BFG AT/KO, Front & Rear Weathertechs
[SIGPIC][/SIGPIC]
VooDooDan is offline
Sponsored Links
Advertisement
post #2 of 73 (permalink) Old 08-21-2009, 10:37 PM
jeepnuts311's Avatar
Send a message via AIM to jeepnuts311
Re: DIY: LED Puddle Lights
nice! looks great.
-Tim
2008 Tundra RCSB, Slate Metallic, Sport Appearance Package
5.7L, 6 Speed, 4.10s
McGaughy's 4"/6" drop
22" Boss 331s wrapped in Nitto 305/40
Custom true duals with X-pipe, 18" Magnaflow
Black headlights, anytime fogs
Hella Celis LED taillights
20% tint on stock privacy glass
35w 6000k HID lows and fogs
Superflux LEDs custom installed in door handles
Homelink Auto-Dim mirror w/ compass and LED console light
jeepnuts311 is offline
post #3 of 73 (permalink) Old 08-22-2009, 10:15 AM
ninja ed's Avatar
At first I thought the light in the wall was from ur mirror then I looked closer haha. Looks awesome. Good job and nice write up. You should figure out how to make tow mirrors autofold now so I don't have to buy 2010 tows haha
[SIGPIC][/SIGPIC]
No Fear Grille, 20x12 Fuel Hostage, AMP Steps, Pocket Style Flares, A.R.E. LSX, , 3 KC 800's, AD Bumper Insert, Oracle Halos, 12'' Bulletproof Lift, 37'' SS-M16, Volant, 26'' PowerSticks w/ RBP Tips, and much more!
ninja ed is offline
post #4 of 73 (permalink) Old 08-22-2009, 10:52 AM
VooDoo,
Great pictures and write-up. I've been waiting for pics of this DIY. Thanks !!!! What exactly, did you cut? Are you separating the clear plastic cover from the housing or did you have to cut the lens too? Can you provide a little more detail on how to access the housing? I thought I read from VLEDs when he did the mod, that he cut the lens and it wasn't for the faint fo heart......
Any suggestions on how to remove the lens, given what you did?
THANKS Again !!!!!
8SM
08SalsaMax is offline
post #5 of 73 (permalink) Old 08-22-2009, 11:20 AM
zpaul's Avatar
Nice write up. Thanks for the pics!
Can you elaborate how you took them out from mirror housing?
Other options.
That is how the last one looks on v-leds truck But it took some skills to fit it in
2011 F150 Eco-boost Lariat
zpaul is offline
post #6 of 73 (permalink) Old 08-22-2009, 01:47 PM Thread Starter
VooDooDan's Avatar
I am not that good yet. I will get some better photos of them installed tonight.
Originally Posted by 08SalsaMax View Post
VooDoo,
THANKS Again !!!!!
8SM
I just cut a tad bit around the side of the black housing till it got the clear part that stays in side of the housing. Then stuck a small flat head screw driver in and twisted all around the housing very carefully till the clear lens popped off from the black housing. I did not have to cut the whole lens off.
Maybe this image will help trying to explain it
Other options.
Do you mean taken the lamp out of the mirror?
[SIGPIC][/SIGPIC]
post #7 of 73 (permalink) Old 08-22-2009, 01:54 PM
Thanks VooDoo..... From your new pic, it looks like the lens is just stuck to the housing with adhesive on the edge and that is the bond you have to break to get to the light.
post #8 of 73 (permalink) Old 08-22-2009, 02:01 PM Thread Starter
VooDooDan's Avatar
Correct except I dont think it is glue. It looks like the plastic was melted to the clear lens and I forget what the term for it is called. Maybe some type of platic welding??
[SIGPIC][/SIGPIC]
post #9 of 73 (permalink) Old 08-22-2009, 02:03 PM
Thanks !!!! I was afraid I had to cut into the bottom of the mirror housing, but now know I don't...... points coming your way !!!!
post #10 of 73 (permalink) Old 08-22-2009, 02:11 PM Thread Starter
VooDooDan's Avatar
Oh, I think I didnt understand your question. No cutting of the mirror is done at all. The lamp has 2 clips to pop out of the mirror. Cant get a photo of it. You take a long small screw driver and you push the clip in(from under the glass of the mirror) and the front side of the lamp comes down a tad bit. Then the other side of the lamp with the only black part on the lens on the outside is the other clip. Then it drops out and you can disconnect the wires. Only cutting needed is on the lamp.
[SIGPIC][/SIGPIC]
post #11 of 73 (permalink) Old 08-22-2009, 02:31 PM
zpaul's Avatar
That too.
SO without popping the lens you can't change the bulb?
zpaul is offline
post #12 of 73 (permalink) Old 08-22-2009, 04:06 PM Thread Starter
VooDooDan's Avatar
The lens will not come off with out cutting. It is completely sealed hosing.
[SIGPIC][/SIGPIC]
post #13 of 73 (permalink) Old 08-29-2009, 03:22 PM
LSUMatt1514's Avatar
Has any one else successfully done this? I really, really want to get those dingy OEM bulbs out of there but this mod does scare me. I am still confused about the removal of the lamp housing from the actual mirror (both what and where to cut and how to get the lamp housing out). Any one else been successful? Thanks everyone!!!
Matt
2008 Tundra Crewmax Limited 4x4 5.7L V8 Slate Metallic
OEM Navigation w/ Backup Camera, Sirius, Escort 8500 X50 Radar Detector, Lockpick 2AV, 700W Inverter, Alpine PKG-RSE2 RSES, BakFlip F1 Tonneau, Platinum Edition Grille, AFE Pro Dry Air Filter, Charcoal Filter Removed, TRD Sway Bar, TRD Sport Shift Knob, TRD Sport Pedals, TRD Badges, Woodgrain Interior, Toyota XSP Skid Plate, Toyota All Weather Mats, Chrome Exhaust Tip, Craven Speed Antenna, WeatherTech Side Deflectors and Sunroof Wind Deflector, Full V-LED Conversion, Line-X Bed Liner, Toyota Door Sill Protectors, Tinted Windows
LSUMatt1514 is offline
post #14 of 73 (permalink) Old 08-29-2009, 05:44 PM Thread Starter
VooDooDan's Avatar
Matt
No cutting is needed at all to get the light out of the mirror.. Its kinda hard to explain and I cant get a photo of it. Cutting is only needed to get the clear lens off to access the light bulb.
The clip off to the side holds it in the mirror(see photo above). You have to take a small long flat head screw driver and push the clip and it releases the lamp from the mirror. if you take a flash light and look in side the mirror you will see what I am talking about. Hope that helps you.
[SIGPIC][/SIGPIC]
post #15 of 73 (permalink) Old 08-29-2009, 05:48 PM
beericus's Avatar
awesome mod!! looks great!!!
beericus is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
