tons of wd40?
Motive powerbleeder. I can bleed all 4 wheels and the abs on my cummins in less than 5minsThanks. Yeah, I'm using up the WD40. I am to the point of replacing both calipers. The local Toyota dealer has 19 of the brake pad pins in stock. There must be a bunch of stuck/frozen pins out there for them to have 19 in stock...
Can anyone recommend a one-man bleeder tool?
I have them on my Corolla and they are great. Especially when you have an impatient wife who has "more important" things to do than pump a brake pedal for you. :angrywife:Just get speed bleeders. They have a one way valve so one person can bleed the brakes. You just have to make sure that the reservior doesn't run dry allowing air into the master cylinder.
