1 - 20 of 30 Posts
· Premium Member
This is a continuation, under a new, appropriate thread, of a problem I found while replacing my non-functional sunroof. Previous thread is found here, for backstory/context:
"'02 ltd moon roof repair and interior disassembly"
Upon thorough gutting of my '02 4x4 LTD Sequoia to replace the sunroof, I found that I had multiple bars across the inside of the roof/ceiling. These supports are supposed to maintain the strength of the roof, so I understand that would be foolish to simply cut any of them out.
The problem became a bigger issue when my newly-functioning sunroof slid back into the open position. about 3/4 of the way open, it hit the roof support that's 3rd from the back.
I was able to deflect the sagging roof support to allow the sunroof to successfully close again.
Automotive tire Automotive lighting Hood Grille Motor vehicle
As I understand it, these supports should have the same contour as the roof, and that light colored residue is seam sealer to keep them from "oil canning" and squeaking.
The fact that these supports are no long along the roof suggests that this vehicle may have been involved in a rollover collision, or something similar to cause the supports to separate from the roof.
Problem #1- the 3rd-from-rear support is hitting he sunroof. I'd be happy to simply disconnect the motor and reassemble everything and call it a day, as I don't really care about the sunroof as long as it's shut and sealed. But that's not the way this is SUPPOSED to work.
Hood Motor vehicle Grille Automotive lighting Vehicle
Automotive tire Automotive design Rim Automotive exterior Wood
Problem #2- What's wrong with these supports? I bought this anciently used vehicle as a family transport module, and I want it to also keep my family safe in the event of a bad collision or rollover.
I'm about to get on the phone with local body shops to ask them what they think, if they're kind enough to listen.
If I don't get any definitive solutions or suggestions, I will probably cut the offending support in the middle, and mend-in a ~1/8" steel flat bar about 3' long, and drill/tap it to screw in to secure them, and/or maybe tack weld them together (that thin roof support's gonna disintegrate quickly, though).
2002 Toyota Sequoia Limited 4x4
A roll-over? Maybe not. A three ton car would crush the roof a bit more than that and bend more than just one roof rib. If I were betting, I think someone loaded something on the roof not on the roof rack bars or stood on the roof. The roof skin popped back out, but the rib underneath stayed bent.
If you have access to a torch and have the know-how, you might try using a bottle jack with a length of pipe to flex the rib back into shape while adding a little heat. You might be able to stretch it back into place. Can't loose much by trying before your plans to chop and replace.
06 Sequoia Limited, 4WD
I believe this is the same material used to bond the hood skin to the framework around it. I had the same issue with an older hood, which later got damaged. Dealership did the paintwork on the front end, and they bonded the skin back on with a special caulk which matched the appearance of the original hood, which appears to be the same color as your supports. You may want to research that a bit. I've had no issues since it was repaired. I recall reading that it was a very strong adhesive that took a lot of pressure to apply.
· Premium Member
Discussion Starter · #4 · (Edited)
Update:
Thanks for your responses.
After discussing this at length with my wife, I've realized that I may hem and haw over this for the remainder of 2023, and still be uncertain as to what to do. So I've decided that I'm going to try to execute the plan I had previously declared. My concern about relying on any adhesive is that this support seems pulled taught between the walls, and I just really doubt that I can put any adhesive that will keep this beam deflected at its current length. And the same reasoning is why I'm not going to try to bend it with a bottle jack and heat it. At most I MIGHT stretch it, but.... I don't want to drag this action into next week.
The picture below shows the sun roof removed. You can see that there's actually a 4th beam, which coincides with the rear of the sun roof opening. I hadn't previously noticed it. It appears to still be pretty close to the roof.
Vehicle Car Motor vehicle Hood Automotive lighting
The picture below is a close-up of the 2nd-from front beam, which is the offending member.
Vehicle Hood Motor vehicle Automotive lighting Automotive carrying rack
· Premium Member
I started working and.... appreciated the value that SilverSquatch had shared about how easy it would be to try pressing it into place & torching it. So I've heated it a bit after pressing it up with bottle jack. I guess I'll give it 30 min or so to cool off, then remove the jack and see what's what. If that doesn't do it, it's grinding time.
Vehicle Motor vehicle Hood Car Automotive design
Update
Hood Automotive tire Motor vehicle Bumper Automotive design
Why not take those pics to your local body shop and ask them about it? I would be willing to bet they've probably seen this before and would know exactly how to fix it, and tell you how much it would be to fix properly. Hell, they might even tell you how to properly fix it yourself.
What do you have to lose except for maybe an hour or 2 of your time to stop by?
· Premium Member
UGH! you mean wait until MONDAY?!
honestly, that may be a good idea, I just don't expect that any body shop is going to give me the time of day. I suppose that, if I'm a potential customer, they may. I've already gutted the thing, so I've done a lot of the work for them, and they don't have to be precious with my upholstery.
sigh. maybe you're right. Honestly, I just REALLY want this problem behind me, but, I think you probably raise a good point, which I'd already dismissed due to impatience. Impatience isn't how to get things done right.
I think I'll wait, and ask a body shop about it.
· Premium Member
The press-and-heat method seems to have made some improvement, but I don't know how permanent that is.
the "before" is on the left, and the "after" on the right. Sorry I misused landscape vs portrait.
Automotive tire Automotive lighting Hood Bicycle tire Motor vehicle
· Premium Member
Discussion Starter · #9 ·
I made it by 3 body shops today.
#1 said they could make an appt for me for wed morning.
#2 went and got his lead tech/manager. He explained that he wouldn't repair it unless they also changed the roof. He suggested that one might think you could press it into place, but he questions the structural integrity of that. He would get me the relevant quote tomorrow morning.
#3 said it didn't seem like something he could do, but "let's take a look at it". He said the proper way to do it would require a roof replacement, but that would be about $3k-$4k or more, and his shop isn't set up to handle that. "For my money", he said he'd press it into place, bringing us back to the suggestion of silversasquatch. He mentioned that the adhesive used between the support and roof is "foam adhesive", which he expects that I could pick up at an auto parts store.
So I think I'll try to clean the residual adhesive off, maybe use an angle grinder with wire wheel, then press it, heat it, cool, relax it, press it, heat it, cool, relax a tiny bit, apply adhesive, press again, and leave it pressed for a (few) hour(s).
Then repeat with the other ones. I have 2 bottle jacks, so maybe I can find another piece of pipe to get another one going.
Side note, I took this waiting period as an opportunity to apply sound damping material and replace the interior lights with LEDs. Here's a pic, because everyone loves pics.
Car Vehicle Hood Automotive tire Automotive lighting
3 to 4 K? WTF?? OK, I guess I am wrong. So much for me thinking body shops wouldnt try to rip you off.
Are you going to apply the same sound deadening on the roof when you're done? I bet it would cut down huge on the heat with that hot Texas sun beating down on you in the summer.
And you're still my hero for gutting your ride this extensively. LOL.
I’d put a 2x4 up on that cross bar and slightly over jack the thing and see if it pops back into shape. If not, I’d then slightly over jack it again after first applying Gorilla Adhesive along those seams. Let the glue set over night. Use the Faster setting Heavy Duty Gorilla Adhesive in the Caulk Tube from Big Box. Or, use FuzeIt by Liquid Nails. I’ve used both on my truck on the inside and out on various items needing it. Still holding and the bonus is the Adhesive is a sound deadener!
Edit: Remove the old glue first.
· Premium Member
Discussion Starter · #12 ·
Yes, I plan to apply sound damper to the ceiling once I get this fixed. Some break from the sun's heat would be very appreciated.
· Premium Member
Discussion Starter · #13 ·
Is there any concern that I want/need to maintain some flexibility in this joint?
I did already press it with a 2x4 against it, and there was no "popping" back into place. It seems to be more "stretching" than anything else.
Are you talking about THIS product,
Gorilla Heavy Duty Ultimate Construction Adhesive, 9 Ounce Cartridge, White, (Pack of 2) https://a.co/d/1ULDLYt
or something else?
Yeah. The metal needs to be over stretched/over jacked slightly. Trick is not ruining your roof line. This is the shtuff. It has some flex to it and is the reason I recco’d it.
Another idea (in addition/conjunction to what I explained above in the prior post) is to add a long flat steel plate (the width of the arch by approx. 1” wide x 1/8” thick) in that natural groove in the existing arch. Load it up with glue and jack into shape when you glue the other stuff. Let dry and remove jack. Should act as a splint and stiffener. You may need to pre-bend the metal to the arch first but you get the picture. Maybe add some short sheet metal screws in the mix.
Liquid Drink Font Solvent Wood
· Premium Member
Discussion Starter · #17 · (Edited)
Before I started cleaning up the adhesive:
Motor vehicle Hood Automotive lighting Automotive exterior Cloud
After some moderate cleanup:
Hood Automotive lighting Automotive exterior Bumper Automotive tire
I neglected to get a picture of how it looked when I finished cleanup. I applied a wire wheel to it with my angle grinder, and.... I don't know that it was worth the effort.
Vehicle Motor vehicle Automotive tire Automotive design Car
Bicycle Wheel Bicycle wheel Gas Building
· Premium Member
Discussion Starter · #19 ·
So, the setting is underway. I realized that the beam is not well pressed against the roof near the edges of the roof, which... is expected... but I thought I could apply some improvisation to improve the circumstances. I'm embarrassed, and you're welcome for the picture. I suppose that a longer 2x4 will deflect enough to allow some roof curvature, but... I'm just not really sure. So I cut a longer 2x4 for the next one.
Motor vehicle Car Vehicle Automotive tire Snow
2000 tundra 4.7 4x4. Not much stock on it besides the engine
I do Collision work for a living and replaced quite a few roof skins. Your's was definitely replaced at one time, probably when newer back before carfax was big if it has a clean title. A lot didn't get reported if it was an rent a car. I've put cars back on the road that shouldn't of been with clean titles. Look around towards the back of the skin and pull the weather stripping back and look for spot welds to know for sure. I've never seen a factory roof skin painted like that in 25+ years I've been doing this
1 - 20 of 30 Posts
