Hi, I'm new to the forum and have a question regarding the check engine light. It has been on for some time now. I went for my emissions test and they saw the light, plug in the tester and stated there was a PO 420 code referring to the catalyst system. I went to the local Autozone and used there tester, which came up no codes. The light went off on the way home. Do I take it back for the emissions test (1st one failed) or could it be something else?
They may have cleared the could when they had the scanner hooked up. Many times after clearing a code it may come back in a day or two or even a couple of weeks. Then again it might never come back.
Drive for a couple of days and if the check engine light doesnt come back you might be good to go, but seeing that P0420 is a cat problem you might need it replaced.
Check these threads out:
http://www.tundrasolutions.com/forums/1gen-tundra/189822-check-engine-light-damn-2/
http://www.tundrasolutions.com/forums/4runner/92162-p0420-p0430-codes-when-will-end/
