Hi Everyone,
My Sequoia has a leak at the seal between the end of transmission and the propeller shaft. Please see attached pix. Have anybody replaced this seal yet? Any help would be very appreciate. Thanks
Well, i found a TSB No. DL001–07 for 04 Tundra which can be used for Sequoia, please attached pdf. Have anybody has this problem on 04 Sequoia?
Discussion Starter · #2 ·
some mechanic suggest that apply the J-B weld over the end cap of the slip yoke should stop the leak for good. I think i will try that rather spend a lot of money to replace the slip yoke and u-joint.
J-B weld works really good, no more leak! Try it if you run into the same problem. Thanks
