1 - 7 of 7 Posts
I want to remove my stock head unit. new at this I don't know where to start I removed three screws under heater controls but dont know what to do next. Pictures would help! there is a cd stuck in the 6 disk changer
there are two more screws behind the vents ....if you push them in pointing to headliner you see them on the back
I attached a pic, but just push the vents up and you will see a screw, it took me a while the first time also.
Andrew
Maybe his navigation unit is like mine, I have an Alpine double din unit and the nav is dumber than two bowls of hair. So, sometimes I use my portable unit to keep from ending up in East St. Louis.
i dont have the gps hooked up to the head unit because like randyeverett said its horrible and the hundred dollar garmin with 2005 maps does a way better job.
Andrew
1 - 7 of 7 Posts
