1 - 7 of 7 Posts
I found the LSD tag on my rear diff on my 05 tundra. But before i found the tag i had the rear jacked up trying the spin method to figure it out....with the truck in park i could spin the tires,,,,with the truck in nuetraul both tires would spin the same way....Is this normal?
If it spins the same direction, it means you have an lsd. Not sure why you could spin the tire in park though.
Im confused as to why is spun the tires in park tho
was out on wet roads today and it for sure spins both tires.
Because putting the transmission in park has no effect on the rear axle. It stops the rear driveshaft from spinning which will "lock" the rear axle when the tires are on the ground but with both tires off the ground the rear differential will still spin but the rear driveshaft will not.
1 - 7 of 7 Posts
