I replaced the fuel pump right off the bat because i could not hear it pressure up when key turned on still no start. Have checked fuses, swapped relay. Looking for more ideas. Can evap pump module cause a no start?
I don't have any error lights.Loose gas cap will do it. Possibly no tank vacuum or a leak. You will get dash error lights. Cam.
Tried both keys, light goes out for both keys. Swapped relay with no change.Did that make the fuel pump run? Fuel pump relay, ignition switch, immobilizer/key. Try a spare key if you have one.
NO and NO.. nothing to do with it people.Would a bad evap module do it?
So...there's about 20 matching descriptions, all different part numbers. No clue which one does the fuel pump.I usually go on something like toyotapartsdeal to research part numbers.
I agree that one seems more relevant. But I would like someone who is more knowledgeable in this than me to confirm it is not one of the many that says: Computer, Engine Control. They are too expensive for me to simply make an educated guess.
It literally says fuel pump control computer assembly and there is only one on your vehicle and one on the list. If you have any doubt find the part, get the part number off of it and look it up.I agree that one seems more relevant. But I would like someone who is more knowledgeable in this than me to confirm it is not one of the many that says: Computer, Engine Control. They are too expensive for me to simply make an educated guess.
(a) Disconnect the 2 fuel pump ECU connectors. | ![]() |
