Tundra
I have an 07 tundra that will not go into programming mode with the door open and closed door lock unlocked and key in on and on and off nothing. I don’t even know if the key fobs work because the truck will not do the unlock to go in the programming mode
2005 Toyota Sequoia Limited
Take to a dealer and have them program them, should cost about $60. Tech stream has a bunch of options in the system to change different features anyway. Have them print you the list and select what you want changed while you're there
2008 Toyota Sequoia SR5 2x4 5.7L
You can not program a new key or fob to a 07 and up Tundra or 08 and up Sequoia without the Tech Stream or software on a Laptop and aftermarket OBD-II cable.
