so my outside mirror are automatic tilting down when going into reverse, then they are supposed to go back when going into drive. however, seems tempermental, it only does it about 25% of the time so then i have to manually adjust from the inside with the controls.
anyone with similiar probs,,,, is it a hard fix or not? thanks
Yeah, I've had some quirky issues with that feature as well. It's a little bit inconvenient to reset the mirror(s) manually, but I don't feel like anything is really broken per se, so I haven't looked for a fix. I've just taken to only using the feature when I really need it and leaving it off most of the time.
You have to leave the mirror selector switch on either mirror. It will not work when it's in the middle position.
