1 - 10 of 10 Posts
I am trying to replace the rotors on my truck and can't seem to get them off. I already took off the caliper and broke loose the rust. Is there something else holding it on?
There is a place where you can screw a ten milimeter screw to pop it off. I hope you know what I mean. It is located right in the front.
Here you go. Looks like it was covered in a previous thread.
Toyota places two bolt holes in the rotor for the purpose of rotor removal. Screw two bolts into the holes and they will push the rotor off the hub. They should be M8 x 1.25 thread...
Thanks guys. I tried the hammer and had a hard time getting it off. But the bolts worked splendidly.:)
1 - 10 of 10 Posts
