Well,
I've compiled some numbers after running the initial 10 tanks through the 05' DC since installing the BAM per Keith's recommendations over at Dirty Deeds. With the factory exhause, I was averaging 18.5 - 18.7 mpg setting the cruise at 60 mph and driving mostly highways back and forth to work....
Work has since picked up, and I am doing a lot more driving to and from job sites, and get tied up in construction zones a little more then I'd like. Since installing the BAM, I decided to begin setting the crusie at 65 mph, and since we've seen a few days at 100+ degrees, I started running the a/c....anyway, when not in heavy traffice, I am seeing about 18.3 - 18.6 mpg....I am going to call this a slight improvement over stock since my mileage is essentially the same, but my speed has increased.
I've put together a small spreadsheet, hopefully I can insert it....
EDIT: It didn't copy like I'd hoped!
Overall Numbers...3096.92 miles driven.....168.43 gallons pumped......18.4 mpg cumulative.......
