Anyone know where a switched 12V wire can be found on the back of the truck? I am installing an aftermarket backup sensor. I know there is one in the trailer harness, but that wiring is difficult to access, so I wondering if there is one on either of the sides of back?
Thanks,
Matt
Why not use the reverse light wire? Your sensor will only come on when you're actually in reverse then...
the system uses three sources - the reverse light, the brake light, and a 12V source (which i presume controls the LED display).
if it's for the display, why does it need to be in the rear? Is that where the display is going to be? I'm confused...
