Oil is leaking from the ignition coil (back, passenger side) and falling on the exhaust manifold. I guess my question is:
1. Is it leaking becuase the tube seals are bad?
2. If so, can the tube seal be replaced without removing the valve cover?
3. What is the tube seal made of? Is it rubber, or some kind of metal/rubber seal that is pressed on at the factory?
Looking at the the valve cover, I don't think that the upper intake has to be removed to remov the valve cover. The driver's side is a different story but it isn't leaking.
Any information that can help me with this task will be greatly appreciated. I appreciate your time with this in advance.
Have a blessed day! :beatsme:
