I have a 1998 Toyota Tacoma 2wd with a 2.4 engine. I recently removed a radio power amp under the seat. I taped the power leads and they shorted out filling the cab with smoke. I realized what happened and ripped the wires out. I soon found out that the installer connected the lead to the ecu-b 15 amp fuse instead of the radio 7.5 fuse. Now the truck starter will not turn on, ac fan, radio, odometer, and blinker will not work either. As I tried to push the truck down hill with the ignition on and pop the clutch it started. After driving it home, I tried to start it and will not start. Any ideas?
