I've been a long time viewer of the forum but first time posting. I'm about ready to pull the trigger on the Bilstein 5100 upgrade (front and back) for my 2001 AC because it's about time and based on everything I've read I probably should have done this years ago. I've decided to keep the truck (only 130K miles since original in 01) and therefore it deserves an upgrade. In any event, I am debating on whether to go with the 4th or 5th notch on the front 5100s and if I would need a 1" block if I went with the 4th notch or the 5th notch to make it approximately even.
In other words, those of you that have this mod on your 1st gen truck, what do you recommend? Do you have any photos you can post? I've seen a lot of photos with the middle notch or the top notch but not any with the 4th notch.
Also, what is your experience thus far? Now that you've had this upgrade done for a while what are your thoughts on going with the full lift (4th/5th notch) in terms of ride quality and alignment issues, etc?
For reference, I have the TRD wheels with 285/70/16 tires all around. I don't have a current photo of the truck but it currently has a 1-2" rake (back higher than the front) and it appears that the passenger front side has less of a gap between the fender and the tire than the driver's side. About a 1" difference.
Thanks in advance for any and all responses. When I get a chance I will post a "before" photo and then an "after" photo once I decide and get the installation completed.
